01-15-2012, 11:48 AM | #1 |
200cc Gio T3 bogging, stalling and backfiring
Hey guys,
I just got my T3 in October. Up until about a month ago it ran fine, it would start up no problem, I could drive it around all day and it would have plenty of power etc. Then one day I was out driving it and it would bog down and sputter and backfire. Eventually it stalled and I couldn't get it to start for 30 seconds or so. I thought at the time maybe it overheated so I let it sit for a few minutes and then it started up, but it died again on a long highspeed straight away where it would have been getting plenty of cooling. The bogging/stalling and backfiring seems to happen between 1/4 and full throttle. This to me suggested that maybe with the drop in temps over the last month I needed to make some carb adjustments. So I read the guide on adjusting the carb, set my idle and mixture screws, and moved the float needle to the very bottom ring. Still no luck, I took it out today in -10 weather after a 10 minute warm up and it started doing it again. Its to the point now where I can't even hit high rpms in second gear. Let me also include that everything is stock, carb, cdi etc. I checked my spark plug, it is black around the threads and igniter, but the very tip where the metal probe(?) hangs over the igniter is white. I assume this means I'm running too lean. Anyone have any ideas where to start? |
01-15-2012, 11:56 AM | #2 |
I'm no expert on carbs but it almost sounds like your main jet is plugged or dirty. Also, if the outside temps have dropped a lot you might have to go to a fatter jet, a white electrode is way to lean.
I never could get my 200cc Beast to run right with the stock carb, it was always bogging and sputtering no matter how I adjusted it. In the end I bought the upgraded carb off GIO's auction site, a few minor tweaks and it was purring like a kitten . |
01-15-2012, 12:35 PM | #3 |
MICRider speaks the truth, as usual.
I bought a 30mm Mikuni and installed a 110 main and 25 slow jet, and haven't looked back. It runs great, hot or cold.
01-16-2012, 12:14 AM | #5 |
Show us the eBay link you found, and one of us will let you know.
01-16-2012, 09:07 AM | #6 |
01-16-2012, 11:22 AM | #7 |
That's exactly the style I've installed a few times. You'll need to swap over your existing cable choke assembly and change the jets, but it'll be great.
I used this filter with it: 42mm Air Cleaner It has a better angle than a Uni, and it's far less expensive.
01-16-2012, 02:54 PM | #8 |
Thanks Weld! I ordered the carb and some air filters. I'll check the cycle shops around here, hopefully they carry carb jets.
01-17-2012, 12:42 AM | #9 |
You're welcome.
Be sure to oil the inner core of the filter with quality oil. I use Maxima Fab1 filter oil. Good stuff.
