Old 03-16-2020, 04:03 PM   #1
ViShOuS   ViShOuS is offline
ViShOuS's Avatar
2020 TaoTao Hellcat Performance Upgrades
Hello again! Ok I havent seen too many posts on performance upgrades on here so I figured I would start this thread.
I will post performance upgrades ive found, where I found them and how they performed. I hope others will follow suit and post upgrades they have found (that are still available) and give a review.
Old 03-16-2020, 04:06 PM   #2
ViShOuS's Avatar
PZ20 Carburator
Although everyone has suggested the VM22 unless you change the intake manifold you wont get more than 20mm anyway so i went with this $13 carb from amazon it is adjustable and has cheap jet kits available, but right out of the box with a slight adjustment to air/fuel screw it has added power and eliminated the bogging the factory carb would do at times.
https://www.amazon.com/dp/B07NTX9X57...p_mob_ap_share
Old 03-16-2020, 04:07 PM   #3
ViShOuS's Avatar
17 tooth 17mm front sprocket from Amazon.
Another cheap upgrade that has helped stretch the gears and added about 5mph to top end.
https://www.amazon.com/dp/B010UQK6NY...p_mob_ap_share
Old 03-16-2020, 04:11 PM   #4
ViShOuS's Avatar
Airbox delete
K&N filter did not fit right in the box so I just did the delete. All I had to do was remove the box (2 screws) I didnt turn around the intake manifold yet and dont think i will i dont like having the air filter behind the front tire seems like a bad idea for dirt and even water if you get caught in the rain.
DOES NOT FIT HELLCAT
K&N airbox filter
https://www.amazon.com/dp/B00RAQNR0C...p_mob_ap_share
Cheap filter that fits and has nipple for exhaust vent.
https://www.amazon.com/dp/B07BNTSHW4...p_mob_ap_share
I ordered K&N 62-1460 will update when installed
Installed it today much better throttle response as always K&N does not disappoint!
https://www.amazon.com/dp/B00029WXUO...p_mob_ap_share
Old 03-16-2020, 04:12 PM   #5
ViShOuS's Avatar
I just order the 6pin cdi that gets rid of the rpm limiter. Will let yall know
Installed it today noticed 0 difference before installing new K&N filter, but it is plug and play and cheap enough. With K&N filter much better throttle response.
https://www.amazon.com/dp/B00UBTKWY4...p_mob_ap_share
Old 03-18-2020, 02:26 AM   #6
kirbo7106's Avatar
Swingarm
Hi,
I like the Kepspeed swingarm. They have several models. Here’s a video on YouTube on Kepspeed swingarms:
I went with this model from Kepspeed
Enjoy the Ride!
Dan-O
-2018 Tao Tao HellCat - DOA
Old 03-18-2020, 02:16 PM   #7
ViShOuS's Avatar
Ok got the fender delete and new tail light with built in blinkers both perfect fit (plug & play)
Fender Delete
https://www.amazon.com/dp/B07NZS5YYY...p_mob_ap_share
Tail Light (Recommend if doing fender delete or turn signals will be close to exhaust)
https://www.amazon.com/dp/B078JP27KV...p_mob_ap_share
Flush front turn signals comming soon!
Old 03-20-2020, 05:51 PM   #8
ViShOuS's Avatar
Fender delete, flush turn signals and tail light installed
I like it I like it A-lot
Old 03-20-2020, 05:57 PM   #9
kirbo7106's Avatar
I like the Dead Pool decal!!!
Enjoy the Ride!
Dan-O
Old 03-21-2020, 04:08 PM   #10
kirbo7106's Avatar
Exhaust System
Here’s the exhaust system I purchased for my HellCat!
There are a couple of mounting spots under the transmission to mount the muffler.
Enjoy the Ride!
Dan-O
Old 03-23-2020, 05:13 PM   #11
ViShOuS's Avatar
You got a link?
Attachment 20552
Enjoy the Ride!
You have a link to it? And hows it sound?
Old 03-24-2020, 05:04 AM   #12
kirbo7106's Avatar
Link for Exhaust
Here’s the link on eBay:
https://www.ebay.com/itm/Stainless-S...b-789e55bd1025
There’s a link for the sound:
This is not my bike. Currently, I’m still incapacitated with neck surgery recovery.
Enjoy the Ride!
Dan-O
Old 03-24-2020, 08:10 AM   #13
ViShOuS's Avatar
Enjoy the Ride!
Damn bro that sucks hope you heal up quick!
Old 03-24-2020, 09:12 AM   #14
kirbo7106's Avatar
Thanks! It does Suck! I have Parts laying around to install on my HellCat, but I can’t do anything!
On the good side, it’s been over a week since the surgery and I have 10 days until I go see the surgeon for follow-up.
Enjoy the Ride!
Dan-O
Old 03-24-2020, 05:56 PM   #15
kirbo7106's Avatar
Exhaust Clip
Here’s another under-slung exhaust pipe:
Enjoy the Ride!
Dan-O
