Old 07-24-2020, 02:06 PM   #1
Smcknight18   Smcknight18 is offline
Smcknight18's Avatar
Hawk 250 2nd gear slippage
Just wondering if anyone else has had this issue or maybe its because my hawk is still pretty much brand new. When shifting into 2nd gear, after a few seconds, the motor slips back into neutral. Not all the time but sometimes. Just wondering if it's the cable that needs to be tightened or something else?
2020 RPS Hawk 250 EFI
Old 07-25-2020, 01:51 AM   #2
aaw611   aaw611 is offline
Do you have a lot of play in the clutch handle? Have you changed the oil? Make sure you are using a JATO spec oil without the friction modifiers in car oil. Use a motorcycle specific oil, rated for wet clutches, or Shell Rotella for diesel engines.
Old 07-25-2020, 07:00 AM   #3
Just changed out new oil and using specific oil type for the motor that was mentioned in the manual. Clutch has been tightened up and has very little play now. I have not reached the break in point yet. It only has about 92 miles on it. So we shall see what happens over the next few days or weeks
Old 08-15-2020, 08:24 PM   #4
emptypockets   emptypockets is offline
My 2017 hawk did this when it was new, neutral was either impossible to find or it would randomly pop back into neutral from 2nd. I haven't noticed it do this in a few years, now that it has a few thousand miles on it it shifts more smoothly.
Old 08-16-2020, 09:38 AM   #5
herbie   herbie is offline
Maybe try taking the shift lever off and moving it down a tooth. It could be that your not getting good engagement into second gear.
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
