04-19-2021, 02:57 PM | #2 |
Download the Honda CRF230F Shop Manual. It will come in handy. https://www.google.com/url?q=https:/...i2fu68lr12Kmu9
04-19-2021, 03:15 PM | #3 |
Also when removing the valve cover make sure you don't lose this little black rubber plug. Make sure you reinstall it too. Very easy to misplace or lose.
04-20-2021, 07:39 AM | #5 |
Must be tight spaces if you have to hang it from the ceiling.
04-20-2021, 09:25 AM | #7 |
Akshualllllyyy.... Hanging from the ceiling allows working while standing up rather than having to sit on the floor...
Wifey must be soooo happy you have a hobby. Annnddd stay home all the time instead of hanging with your buds... on the golf course, at the pool .. etc. Thing is, she wants access to the washer/dryer. On her terms. tom
vertical and above ground - my daily goal |
04-20-2021, 11:06 AM | #8 |
I wish it was hanging from the ceiling. My knees are killing me today!
Can someone point me in the direction on how to post pictures the right way? |
04-20-2021, 11:14 AM | #9 |
Fixed it.
04-21-2021, 02:21 AM | #10 |
So I am really confused right now. I pulled the head and I notice it has roller rockers. I look at the cylinder and was like “that looks bigger than the 67mm piston for the big bore kit. I start measuring and it seems that the bore is around 68mm on my stock cylinder. I lowered the piston down into the cylinder to see how the new one looks compared to the stock cylinder and sure as sh$& the 67mm drops in with room to spare. I measured the new cylinder and piston and they are 67mm. What on earth is going on?
04-21-2021, 07:39 AM | #12 |
Looks like you have the new 249cc engine. My stock piston was 65.5mm. Hmm, Maybe need to check what's on my Ghost.
04-21-2021, 08:01 AM | #13 |
The thing is still stamped and labeled as 165fmm in two spots on the crank case. What does this mean for the aftermarket parts like the cam. Is there a performance piston for that size bore?
04-21-2021, 08:07 AM | #14 |
I guess I'll find out when I remove my head. I have a head already ported and ready to install. I guess I better check before ordering a cam.
