07-07-2017, 01:50 PM | #1 |
Am I missing something here?
Ok, so I figured I was being simple when you guys said this LED cob light was plug, and play, but i really cant find out where it plugs into to!!! lol Theres no plug in......
07-07-2017, 02:05 PM | #2 |
Defiantly a different setup than the Hawk. What kind of bulb did they use? Still not a big deal. Should be able to just cut the wires and match colors.
07-07-2017, 02:12 PM | #3 |
You can but, ive ran into another prob...... None of the adapter pieces work for the headlight assembly.. lol Used just a halogen bulb
07-07-2017, 02:19 PM | #4 |
Have a picture of the original bulb?
07-07-2017, 02:21 PM | #5 |
Ill take a pic of it when i get home, and post it.
07-07-2017, 02:24 PM | #6 |
You should have one adapter with 2 prongs that should work.
07-07-2017, 02:33 PM | #7 |
If all else fails you maybe able to modify the existing bulb socket to receive the new bulb. Looks like the ID is about the right size.
07-07-2017, 02:37 PM | #8 |
Your existing bulb must be like this one. You can get a LED bulb in this style but you would be better off converting and making the one you have work for two reasons. 1. it has a constant power supply drive and 2. it has a cooling fan.
07-07-2017, 07:34 PM | #9 |
And if all else, all else fails, put the one you bought up for sale on here and recoup some of your money if you don't think you can make it work. Might take a couple dollar loss. Or if you have a car/truck that uses H4 bulbs, buy another one and use them in that lol.
