Old 11-06-2021, 02:39 PM   #1
Tomkay44   Tomkay44 is offline
TBR7 Tune Up Stock Carb
I hacked the stock carb open and stuck the 110 jet in there. The air fuel mix screw was around 2.25 turns from the seat. I seated it and came 1.5 out on it. I DIDN'T PUT THE TWO SHIMS/WASHERS ON THE THROTTLE NEEDLE because I'm the opposite of a mechanic and didn't want to screw things up. Here are my 2 questions:
1) Since I didn't put the two shims/washers on, should I have left the air fuel mix screw where it was at 2.25 turns?
2) Is the double shim/washer thing an urgent essential thing
Old 11-06-2021, 04:52 PM   #2
It is not critical or needed depending how your bike runs. Raising the needle (shimming it) helps with 1/4 to 3/4 throttle response. Raising the needle with shims richens (adds more gas) quicker under throttle. The air fuel mixture screw controls idle and affects to 1/4 throttle. The idle mixture screw should be adjusted from 1.5 turns for best idle.
Link to carb tuning:
https://www.motorcyclezombies.com/re...orcycle-carbs/
Old 11-06-2021, 08:31 PM   #3
Thanks Chinarider 27
Would you happen to know the average or, general setting from factory for the air fuel mix screw?
Old 11-06-2021, 10:58 PM   #4
Most of the carbs I have checked are at 1.25 to 1.5. as that is generally the default starting adjustment position.
Old 11-07-2021, 12:46 PM   #5
krat   krat is offline
"Factory default setting" is only a position the factory uses to get the bike to run. It is not the perfect setting for 99% of the bikes on the road. It is just a start for tuning.
A guy in Denver, another in Chicago, and one in Atlanta are going to have very different jettings and screw settings.
Old 11-07-2021, 03:41 PM   #6
buzz   buzz is online now
shims need more gas and gp to a 115 jet . then mess with screw
