Old 11-14-2020, 01:11 PM   #1
Bman62   Bman62 is offline
Go-kart brake issue
I have a 90cc Dinli cart that when I got it the brakes were pulled apart and half of the caliper is gone. I’ve looked a lot of places but can’t seem to match it up. It a cable from the pedal to the caliper, the cable pulls a lever that cams and pushed a hydraulic plunger. Any advice would be great. Thank you
Old 11-14-2020, 08:37 PM   #2
dirtbkr188   dirtbkr188 is online now
dirtbkr188's Avatar
Post up some pictures of the caliper for everyone to see what you're working with.
Old 11-16-2020, 01:11 PM   #3
I tried in my first post and I just tried again but obviously something isn’t working properly
File Type: jpg 1F4F0EB5-6FB9-42FA-ACF2-1F5490E8728B.jpg (157 Bytes, 407 views)
File Type: jpg 5F4F4F85-F30D-4944-AFD9-A7DDF8FF4F45.jpg (157 Bytes, 394 views)
File Type: jpg 3540C84C-DF37-4E36-AA8E-E270A5093832.jpg (157 Bytes, 403 views)
Old 11-16-2020, 01:35 PM   #4
We're having an issue with the site automatically reducing the file size. A temporary walk around until we get it fixed is to reducing the file size to 97kb or smaller before uploading.
2020 Kawasaki Vulcan S
Old 11-16-2020, 01:35 PM   #5
I only have a phone and not a regular PC. Does anyone know how to load pics with a phone?
File Type: jpg 43567253-82A9-4DF2-BF68-78ACDDE19690.jpg (157 Bytes, 413 views)
Old 11-16-2020, 01:41 PM   #6
Old 11-16-2020, 01:49 PM   #7
Old 11-16-2020, 02:01 PM   #8
That is an odd one. I've never seen one with the reservoir on the caliper.
Old 11-18-2020, 07:03 PM   #9
Now do you see my dilemma? What else could I do for brakes?
Old 11-18-2020, 09:03 PM   #10
dirtbkr188's Avatar
With a little forethought and fabrication, you could use a rod from the brake pedal to a bellcrank fastened to a flat plate along the frame rail. The other end of the bellcrank is attached to a pitbike rear master cylinder with a long length of brake line running back to a new caliper. Posting some pics of the kart itself, pics of the frame from the pedal to the rear brake rotor, and where a different caliper would mount would be a big help
Old 11-22-2020, 02:59 PM   #11
Old 11-23-2020, 06:28 PM   #12
dirtbkr188's Avatar
Here's a very basic idea, to give you an idea of what I said above. The rod is attached to the brake pedal so it is pulled forward when you step on the brake. The rod pulls on the bellcrank which is attached to a flat plate mounted to the frame. The other end of the bellcrank pushes on the master cylinder plunger forcing brake fluid through a regular brake line to the rear caliper.
Old 11-24-2020, 07:30 PM   #13
I definitely get what you’re saying. I did order a caliper that seems like it might be close. Well see what happens. Thank you for your input!
