Old 07-01-2012, 11:10 AM   #1
cheesy   cheesy is online now
cheesy's Avatar
It Is Alive!!! Bwahahahahahaha
http://smg.photobucket.com/albums/v4...0-18-36-04.mp4
Now, if I can get the friggin' carbs to stop leaking I'll finish putting it back together. :?
Sad to say, but the Maggot starts better on year old regular and BS plugs than the Hi-Bird ever did on fresh 93 octane and an Iridium plug.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 07-01-2012, 11:24 AM   #2
Another classic saved from the boneyard, well done! 8)
Old 07-01-2012, 10:35 PM   #3
cheesy's Avatar
Thanks.
Got the fuel leak squared away. Triple checking for cracks in the overflow tubes without glasses and in poor light is a waste of time. :oops:
Going to deal with the recalcitrant temp gauge next.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-02-2012, 02:21 AM   #4
Congratulations! When you have time, let's see some photos.
Old 07-02-2012, 11:17 PM   #5
Is it a CX500?
In the Hibird's defence, a low compression motor is a little difficult to start on 93.
Old 07-03-2012, 08:35 AM   #6
cheesy's Avatar
After I get a couple more small issues dealt with, I'll post pics of the 'De-Cafeing' process. Already have the correct bars on it.
Yeah, WnG, it's a CX500
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-08-2012, 05:22 PM   #7
cheesy's Avatar
Sussed the issue with the temp gauge. The 7v regulator for the gauge has left the building. As the regulator is NLA from Honda, I'll be making my own with a LM317T adjustable VR, a couple caps, a resistor, and a pot. Made up a few of these when I converted a few old cars from 6v to 12v.
Adjusted the valves today, too. I want to find the clown that adjusted the valves previously and have his Man Card revoked. No reason for a lash of 3/16" especially when it calls for .08mm IN and .10mm EX.
Just need to check on the cam chain adjustment and waiting on some small stuff from Radio Shack then back together she goes.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-08-2012, 05:29 PM   #8
Originally Posted by cheesy
...Adjusted the valves today, too. I want to find the clown that adjusted the valves previously and have his Man Card revoked. No reason for a lash of 3/16" especially when it calls for .08mm IN and .10mm EX...
8O
I doubt those valves have ever been adjusted before now.
Old 07-08-2012, 06:20 PM   #9
cheesy's Avatar
8O
It was only the left cylinder that was so far out of whack. :? The right cylinder was somewhat in the ballpark.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-09-2012, 10:27 AM   #10
If you don't mind to photograph and detail that process, I'd be very grateful.
Old 07-09-2012, 01:46 PM   #11
X2!
Old 07-09-2012, 01:47 PM   #12
cheesy's Avatar
Can do. Be a few days, though.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-12-2012, 01:28 PM   #13
cheesy's Avatar
I'm still waiting on the stuff from the shack, so I did a little 'customizing' last night. The valve covers were even too cruddy looking for me.
Cleaned.
First coat.
After 12 hour cure time. Wrinkle Black.
The carb tops were pretty groady looking, too, so I shot them with Hammertone Silver.
Feels like I'm actually getting somewhere. :wink:
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-12-2012, 01:42 PM   #14
I like the way those parts turned out.
Can the paint take the heat?
Is that a new TV antenna?
Old 07-12-2012, 01:42 PM   #15
You made very nice color choices. Did you use a high-temperature spray paint?
