Old 04-24-2024, 07:43 AM   #1
dugndeep   dugndeep is offline
Linhai 300cc 4x4 starter clutch
Went to start the atv yesterday and wouldn't turn over.I could hear the starter whirling but that was it.I thought maybe a pin or something had come out of the starter gear & wasn't allowing the starter gear to spin,just the shaft.So I went to taking it apart,air filter box to expose the starter,then 2 screws that held the starter on & found out the starter was okay so it has to be the starter clutch.Went to youtube and found a video which pretty much explains it all on how to replace the starter clutch.
Old 04-24-2024, 07:45 AM   #2
So got on Ebay and ordered a starter clutch,part number 23706 and a gasket,part number 23617.Just to be sure I get a gasket I ordered another gasket from a different seller.
Old 04-24-2024, 08:34 AM   #3
I started this thread by using the Linhai name which is who it is made by,the name on the tank is Vitacci but it has Linhai stamped everywhere so.......
Old 04-24-2024, 09:01 AM   #4
I might not need a gasket but you never know plus the starter clutch might be a weak part on these China made atv's so I'll have extra gaskets.I never had a bit of trouble out of the Tao Motor Bull 200 starter or starter clutch I reckon.It was a good starting & running made in China atv.I am going to have to break it out to use till my parts come in for the Linhai/Vitacci.The Bull 200 should start right up because the only fuel it has ever had was non-alcohol,just like the Linhai.I use non-alcohol in all my small engines.
Old 04-28-2024, 10:12 AM   #5
Got things apart,just waiting on parts.
Name:	DSCI0004 - Copy.JPG
ID:	31345   Click image for larger version
Name:	DSCI0005 - Copy.JPG
ID:	31346   Click image for larger version
Name:	DSCI0006 - Copy.JPG
ID:	31347   Click image for larger version
Name:	DSCI0007 - Copy.JPG
ID:	31348   Click image for larger version
Name:	DSCI0008 - Copy.JPG
Old 04-28-2024, 10:23 AM   #6
I got lucky & the cover come off without tearing up the gasket.Oil pump is right there under the magneto.
Old 04-28-2024, 10:44 AM   #7
The Magneto bolt size is M8-1.25 & I don't have any long enough to pull off the magneto with the Harmonic balance puller I got,the point doesn't come off my puller so it's 2" just to get to the magneto & about 4" to pull it off.
Old 04-28-2024, 10:47 AM   #8
I was lucky I wasn't down the creek somewhere or at the river when the starter clutch went bad.It would have been hell to get it back to the house to work on it.Lucky I had just got on it in the barn.
Old 04-28-2024, 04:39 PM   #9
Jb2487   Jb2487 is offline
Thanks for sharing the video of fixing the starter clutch, do I have to have the harmonic puller to get to the starter clutch or is there another method.
Old 04-28-2024, 06:30 PM   #10
You might could use a jaw puller that goes behind the magneto if it will grab a hold of the back side.You got to watch though,you might gouge the magneto and throw it out of balance.I believe I would just go with a harmonic balancer puller.You can buy a whole puller kit with different size bolts for less than $25 dollars with free shipping on Ebay.That's what I did.
Old 04-29-2024, 08:59 AM   #11
I wonder if there is anyway possible to roll start one of these that has automatic transmission?This one does have hi-low forward.
Old 04-29-2024, 09:23 AM   #12
Probably going to order another starter clutch just to have one.I noticed the starter made funny noises sometimes starting, when I first got it.Would hear a clunk every now & then.Like the clutch might have been hanging up,idk.I don't know who you would call a name brand manufacturer of these starter clutches to maybe order a better one?Probably just order one from Aliexpress.I didn't want to wait on the slow boat from China this time so I paid more to have one shipped from here & not China.
Old 04-29-2024, 09:26 AM   #13
My starter clutch will be here today,still haven't got the magneto off yet,still trying to find longer M8-1.25 locally without having to order them off the internet.My local Fastenal doesn't have the length I need in stock.
Old 04-29-2024, 11:22 AM   #14
I’m not 100% sure but from what I have heard I don’t think so.
Old 04-29-2024, 11:25 AM   #15
I noticed when my atv is cold it starts right up but after it has warmed up I’ll have to give a little throttle while starting and it’s starts up fine and there have been times it sounded clunky too.
