07-16-2020, 09:18 PM | #1 |
Engine wiring
Hey everyone,
I’ve been working on this bike for over a year now and recently got the starter going am excited to get the bike running. But, I have run into a problem and am hoping some of you can help me. There is 5 wires coming from the engine they are 2 white 1 wht/red 1 blk/red and the last one is blk. I have a plug to put the wires into but don’t know what the configuration is. I was wondering if anyone can help me please. Ill try to upload pictures of the wires and the male plug. Thank you so much in advance. |
07-16-2020, 09:18 PM | #2 |
Sorry forgot to mention i believe it is a lifan the engine is a 163fml.
07-16-2020, 11:26 PM | #3 |
The 5 are gear indicator wires
Not needed if you don’t have an led or display for it |
07-16-2020, 11:28 PM | #4 |
Oh that big plug?!
That’s stator n pick up wires Yellow is 2 stator coil pink is another Blue/white is ign pick up coil + Green white ign pick up coil - Black/red strip should be the AC power feed to CDI only when using an AC CDI or ignore if using a DC cdi |
07-17-2020, 01:13 AM | #5 |
Hey Nz
I actually need to know the ones without the plug correspond to the wires on the plug. ( the plug is from the harness the wires that are by themselves are coming from the engine I believe the stator.) I was hoping someone might have the same bike and be able to show me their connector setup coming from their engine. |
07-17-2020, 11:14 PM | #6 | |
Stator charge is about 30v AC CDI power is about 70V AC Then 50/50 change right on pick up coil or trace wires n find + which should be blue/white Green or green/white is earth |
07-19-2020, 06:14 PM | #7 |
Thank you so much I was getting headaches I will try this as soon as I get a chance.
