09-27-2021, 05:31 PM | #1 |
Source for two rubber seals on Brozz front wheel?
Was replacing the speedo sensor on my front wheel today and must have put it back on wrong somehow as it tore up the two rubber seals (one with a thing spring) that go between the sensor and the wheel hub itself once I starting riding it.
Anyone know the proper name for them and a source? the brozz/peace catalog does not show them. |
09-28-2021, 07:57 AM | #2 |
More than likely its the same as the Hawk. 23x37x7. But verify the size before buying. It should be stamp right on the face of the seal. You can pick them up at any bearing supplier.
09-28-2021, 10:09 AM | #3 |
Either that or just buy some cheap calipers and Maddie them, they're metric.
