Old 01-12-2024, 06:44 AM   #1
shojol672   shojol672 is offline
Question Lifan KPR 200 Front sprocket & chain update
Is 16T/ 17T front sprocket cause any damage to sprocket shaft of lifan kpr 200 motorcycle? Is 428 x ring chain ok with that? Is x ring chain have any impact on power and performance?
Old 01-12-2024, 09:41 AM   #2
herbie   herbie is offline
Hello, no a 16 or 17 tooth sprocket won’t cause any damage. I’ve tried both a I believe the 16 tooth sprocket is the best for power and economy on the KPR with the increase in mph capabilities. Yes, the 428 chain is the correct one. As far as the x ring chain goes it’s a matter of personal preference, myself I use a standard chain because it’s all street driven and doesn’t get all the muck in it from off-road travel. But if you wanted to use an x ring chain it would be perfectly fine. Hope this helps
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
#kpm, #kps, #lifan, #lifan kpr 200
