10-21-2018, 12:49 AM | #1 |
Chineeze Digital Speedomoter Problem
hello, I bought a eBay Chinese digital speedometer for my Hawk 250, I thought since it was Chinese as well as the bike all I would have to do is plug-in the plug that fit it, and mount the digital speedometer sensor and magnet and it would work? It didn't work. It didn't even light up. So now I have to figure out whether I have a faulty speedometer out of the box or whether the wiring is correct. Problem is the speedometer didn't come with a wiring diagram and I don't know What colors are what on the hawk. Not even the manual will tell you. the manual for the hawk 250 has a wire diagram but it doesn't tell you the colors. the key was turned on, I thought that the one wire that was all by itself might be a ground but I tried touching that wire two different metal parts of the chassis , but it still didn't come on. Can someone help me with this?. Does someone have the color designations for the hawk 250? Thank you. also my brake light is staying on all the time
10-21-2018, 11:17 AM | #2 |
I was wondering about something like that for mine. I will bump your thread, hope someone will know.
10-21-2018, 11:46 AM | #3 |
Well I don't own a Hawk but I do have A TT250. Considering the wires for Matt's digital cluster (was originally intended for the Hawk) match perfectly color for color to my TT250 I think it's safe to assume the wire colors of both bikes are identical. I figured out what all the wires were when I installed my cluster because it had a wiring issue. As soon as I find where I wrote it all down I'll post it.
Electrician & Electronics Tech 2014 Honda CB500XA 2016 CSC TT250 1976 Honda CJ360T 2022 Honda Navi |
10-21-2018, 12:09 PM | #4 |
9 Pin Connector behind the headlight
Green = Ground Orange = Left Turn Signal Light Blue = Right Turn Signal Dark Blue = Headlight Brights Yellow = Fuel Gauge Brown = Backlight Ignition Power Black = Ignition Power Green with Red Stripe = Neutral Light 6 Pin Connector from Engine Pink = 1st Gear Blue with Red Stripe = 2nd Gear Green with Black Stripe = 3rd Gear Yellow with Red Stripe = 4th Gear Brown with White Stripe = 5th Gear Green with Red Stripe = Neutral Blue with White Stripe = Engine RPM Red (Not Supplied) = Battery Power
Electrician & Electronics Tech 2014 Honda CB500XA 2016 CSC TT250 1976 Honda CJ360T 2022 Honda Navi Last edited by Biker_Andy; 10-23-2018 at 01:25 PM. |
10-21-2018, 08:04 PM | #5 |
What speedo did you get?
10-22-2018, 07:58 AM | #7 |
Not the same as mine but try this.
Lt blue-right turn Blue-hi beam Brown/white-running lights Orange-left turn Yellow/black-tach Green-ground Blue/white-fuel gauge Red-battery Black-ignition switch Six pin plug Green/red-neutral Pink-1st Blue/red-2nd Green/black-3rd Yellow/red-4th Yellow/white-5th I’d bench test the unit to double check the wiring before installing it. If you don’t have access to a 0-15 volt bench power supply, the bikes’ battery will work in a pinch.
10-22-2018, 11:47 AM | #8 |
That's the same cluster my honorary son installed on his F3. IIRC, the eBay seller posted the wiring chart on the eBay page. I don't have a link, or I'd share it. Since his Honda didn't have the same connector, we bought another connector on eBay (for a Kubota, I think), made a cross reference chart to correct the colours and he soldered it together.
10-23-2018, 11:12 AM | #9 |
hello folks, thank you so much for your help but I still need help. what a freaking nightmare!
okay here's the breakdown: I have 10 wires coming from the speedometer, 12 including the speed sensor which is obvious. White Orange yellow/ white Black/Blue Black Black/Red Red Green/White Black Blue/Yellow (Has bullet connector on it) Notes: there is no light blue coming from the speedometer. there is no solid dark blue coming from the speedometer. there is no blue / white coming from the speedometer. there is no pink coming from the speedometer. there is no blue / red coming from the speedometer. There is no green / Black coming from the speedometer there is no blue / red coming from the speedometer there is no yellow / red. coming from the speedometer. there is no yellow / Black coming from the speedometer there is a red on the hawk but not on the pin connector that I cut. it follows through another connector along with the green and the black should I tie the red to the other two? Should I hook the yellow / white on the speedometer to the brown / White on the hawk? There is a yellow / white on the hawk. I was able to hook up the orange with the orange, the black with the black and the green with the green but that's the only combinations that I could do until I find out more information. I've included a picture of the spaghetti. sorry for the trouble, any advice would help. Thank you. first picture is from the speedometer, second picture is of the hawk. MC: I apologize for not purchasing your digital cluster, if I can't figure this out I will have to take a loss because I got glue all over my speedometer to mount it and I'll purchase yours. Thank you. b |
10-23-2018, 11:15 AM | #10 |
Did the cluster come with a wiring diagram? That would help.
10-23-2018, 11:24 AM | #11 |
no it didn't, I wish it would have, I contacted the Chinese seller but they don't know what the hell I'm saying. They're really bad at interpreting English.
10-23-2018, 11:35 AM | #12 |
Look through the other ebay seller that have that same speedometer. One of them may have it in there ad.
10-23-2018, 11:39 AM | #13 |
I found this:
Wiring instructions: (only work with 2 or 4 cylinder) 1. Orange: left turn signal light 2. Light Blue: right turn signal light 3. Dark Blue: low-high beam light 4. Blue and White: water temperature 5. Yellow and White: gasoline gauge take unit 6. Black and Yellow: speed (connected to the engine pulses) 7. Red: positive 8. Green: negative 9. Black: power switch 10. Green and Yellow: hand brake parking lights 11. Green, white magnetic induction line It was here: https://www.ebay.com/itm/15000-RPM-L....c100005.m1851
10-23-2018, 11:47 AM | #14 | |
LOL, you beat me to it. I just found the same thing.
10-23-2018, 12:22 PM | #15 |
thank you guys, I appreciate it, I'll work on this after work again
