06-29-2020, 10:37 AM | #1 |
More mysterious rpm issues.
Around 100 miles on the Hawk now and have re-jetted the carb to recommended specs & adjusted the valves before I road it.
It has a little popping when letting off the throttle. But even more annoying is that sometimes after it warms up the idle drops and it stalls out. If I keep idle set at 2k it doesn't happen but when I have it adjusted for 1.5-1.6k it happens every time eventually. I checked for a vacuum leak with some carb cleaner around the obvious places and didn't notice any difference in rpms. Any ideas? |
06-29-2020, 11:07 AM | #2 |
Adjust valves again
4 time WERA SuperVintage Roadracing National Champion, SCTA Land Speed Record Holder, 3rd AMA Motorcycle GP of Miami |
06-29-2020, 02:49 PM | #3 |
Thanks!
How frequently are people adjusting their valve lash during the break in period? I'll try adjusting them tonight and see if that helps. |
06-29-2020, 05:24 PM | #4 |
I had quite a bit of difficulty finding TDC. At first, I couldn't figure out if I was on the compression or the exhaust stroke. I think the best piece of advice I found was that the valves will be tighter on the exhaust stroke. Disregard this reply in the highly likely scenario that you are not as mechanically inept as me.
06-29-2020, 09:51 PM | #5 |
I adjusted them tonight & they were very loose. And it sounds much better (it was getting pretty loud after 100 miles & an original valve adjustment)
I can't tell for sure until I take it for an hour+ or so ride but that might have been the problem. These engines are solid but old school & I forget it requires constant tinkering. Unfortunately, I'm now running into chain rubbing into the tire issues. I have a new chain and two sprockets coming this weekend and I'll try to figure out a good way to realign the chain guide rail that is way out of wack. |
07-11-2020, 07:53 PM | #6 |
Well, I just can't get this sorted out. Adjusted the valves & thought it was running better. But took it for a ride today and after it warmed up if I had idle set at 1.5k - 1.6k it would eventually just falling and then die. If I set it at 2k it stays running but fluctuates every couple minutes. Sometimes it revs up sometimes it revs down. I can keep it set at 1.5 - 1.6 but when I hit stoplights I have to give it a little gas to stay alive.
When its a cold start it idles fine. Any ideas of what I can check? |
07-11-2020, 08:46 PM | #7 | |
You are rich. |
07-12-2020, 12:17 PM | #8 | |
I agree with Wild Dog
If your jet is on the intake side of the carb, this means a larger jet (as it regulates air). If your jet is on the exhaust side, this means a smaller jet (as it regulates fuel). When you change it out put the Pilot jet screw at 1.5 turns out as a starting point, ride around a bit to get it warmed up, then adjust he Pilot screw up or down to get the idle speed you want; tweaking the idle screw along the way. If it is still doing the same thing, then go another size leaner and repeat.
CSC TT250 Orion RXB 150XL |
07-12-2020, 03:58 PM | #9 |
Thanks guys. I ordered a 27.5 and a 25 pilot initially. I'll throw in the 25 and see how it goes. I'm already at 1.5 turns on mixture.
07-16-2020, 09:11 AM | #10 |
Where did you order those smaller pilot jets from? I'm having trouble finding them for my keihin carb. Only see 32 and bigger slow jets. I have the same issue as you and I have changed out/adjusted everything else.
BuffaloChinaRider on Youtube Bashan Storm 250 (2018) Apollo Db-36 Deluxe (2019) |
07-16-2020, 09:55 AM | #11 |
probably jetsrus..... thats my guess
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 |
07-16-2020, 10:58 AM | #12 |
Just checked they don't have the size #25 for my pilot jet. They have #35 and up. I just didn't want to buy the #25 on ebay for $14 but I might have to suck it up lol
07-16-2020, 11:06 AM | #13 | |
07-16-2020, 01:32 PM | #14 | |
07-16-2020, 04:53 PM | #15 |
maybe these...l??
https://www.amazon.com/TC-Motor-Carb.../dp/B07QXNNM5V
