Old 11-11-2022, 03:06 AM   #1
Dustoff42   Dustoff42 is offline
Upgrading front sprocket? KPR 200
Im thinking about putting a 17 tooth sprocket into the front of my kpr 200 with the stock rear. Is the 428 chain ok for these bikes with that ratio? Has anyone tried this? I notice the 15 t front that comes with it has a metal edge to the inner part of the sprocket that the others I got did not. Will that cause any wobble with the chain?
Old 11-11-2022, 06:30 PM   #2
herbie   herbie is offline
1) Yes, the 428 chain is fine with the amount of hp that the KPR puts out. I would advise a good quality Japanese 428 chain, if you want to upgrade it.
2) Yes, I tried the 17t sprocket and I didn't care for it because the bike just doesn't have enough hp to push it with that high of gearing. Although Jim a member on here is running a 17t I believe and likes it. I have a 16t on mine.
3)No, the replacement sprocket won't cause a wobble because it's thinner than the original sprocket, if anything it may make a tiny bit more vibration into the foot pegs, but I haven't really noticed it.
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 11-11-2022, 10:13 PM   #3
JimS   JimS is offline
Herbie's right - I'm running a 17 tooth and like it. Most of my daily commute is highway miles and it does great and is averaging just over 102mpg.
Old 11-12-2022, 05:11 AM   #4
Two great answers. Thank you guys both. Exactly what I was looking for.
Old 10-22-2023, 04:33 PM   #5
Aj092013   Aj092013 is offline
Thank you for posting this here I've found it helpful in my research of things to do whilst upgrading.
17 teeth, kpr 200, sprocket
