Old 08-07-2016, 11:06 AM   #1
CSaddict   CSaddict is offline
CSaddict's Avatar
Check your right side cooling fan.
Came back from a 250 mile ride and went over the bike visually. Found the radiator hose rests on the right side radiator fan and has pushed it into the radiator and the fan doesn't move. I need to look further into it early this week week to find out if the fan is now damaged or the radiator itself. So check those fans and hoses.
2016 CSC RX3 Ginger Edition
Check out my blog here:
https://www.facebook.com/My-CSC-Zong...0302595973417/
Old 08-08-2016, 09:06 AM   #2
madsocial   madsocial is offline
madsocial's Avatar
thanks for the heads up. We just looked at everything last night. found a few fairing screws were missing. lol
good to just always check everything. thanks for posting this
Cheers!
Rania aka madsocial
2016 Zongshen RX3 (CSC Cyclone)
Pay it Forward!
Old 08-08-2016, 01:35 PM   #3
Lee R   Lee R is offline
Lee R's Avatar
Be sure to check all the welds too, I had one crack on mine. The rubber parts dry rot very quickly as well like the fuel drain hose and electrical connection boots.
Old 08-14-2016, 12:43 AM   #4
Nailed it...
Good call CSaddict! I did about 4 hours today and it was hot. 102' in spots. The bike never pegged the gauge but I noticed when the fans were on, only the left one was on.
I got home and checked and sure as hell, the right fan was being halted by the hose. I'm not sure if this was something that may have misaligned from my last valve adjust or what. I know it was tight...everything is tight inside these bikes.
I thought of using a zip tie or something to pull the hose back a little for a quick fix but ended up making a small bracket and moving the right side of the fan down a scosche to clear the hose and leaving it in its natural place instead. All good now.
Old 08-14-2016, 09:45 AM   #5
Juanro   Juanro is offline
Juanro's Avatar
I checked mine and noticed two things: my fans are different, they have a cover over the rotating fins, and the top hose is routed far of it, anyway. So thanks for the heads up and the additional peace of mind.
Old 08-14-2016, 11:42 PM   #6
Jay In Milpitas's Avatar
Panasonic, hadn't noticed that before.
Old 08-15-2016, 03:06 PM   #7
katflap   katflap is offline
katflap's Avatar
Yep, mine too
Perhaps these "open" fans have only been fitted to later bikes.
Can't really see this style of fan as being an upgrade
Old 08-15-2016, 03:21 PM   #8
Originally Posted by katflap View Post
Yep, mine too
Or maybe it's a U.S. thing. Both of ours are from the early, first shipment here and we have the open fans.
Old 08-15-2016, 03:38 PM   #9
katflap's Avatar
With yours being from the first shipment, then yeah, it does seem to be the case.
I wonder why the decided to change the fan design for the U.S RX3
Old 08-15-2016, 05:13 PM   #10
I know. One would think that they'd have the fans completely shielded here so the high speed toddler that was following you down the road at 60 mph couldn't get their fingers caught in it. ;-)
Old 08-15-2016, 07:24 PM   #11
Mine is a '16 and the fan is open, both left and right. The right fan housing is touching a radiator hose but the fan itself spins freely. I think I'll rotate the right fan down a bit just to get away from that hose.
Old 11-15-2016, 06:57 PM   #12
ElectricCircus   ElectricCircus is offline
ElectricCircus's Avatar
Irate My advice: check both radiators!
Hello.
Last week I´ve found the same situation but on both radiators.
The water hoses pushed over one half of the plastic holding piece, bending it against the radiator surface.
Left assembly:
Name:  left assy [1024x768].jpg
Right assembly
Name:  right assy [1024x768].jpg
On my bike (350miles only) the fan just touched slightly the right radiator surface; but at the left side it eroded the surface and two wings of the fan become broken.
Left radiator:
Name:  left radiator [1024x768].jpg
Left fan:
Name:  left fan [1024x768].jpg
Right radiator:
Name:  right radiator [1024x768].jpg
______________
- ex Honda MB100 (1981)
- ex Honda Nighthawk 250 (1991)
- ex Honda Storm 125 (2009)
- ex Corven Triax 250 Touring (2016) (Zongshen RX3 carb)
Benelli TRK 502 (2018)
Old 11-16-2016, 09:53 AM   #13
Not cool at all Juan Carlos. When I found my right side hitting the hose, I figured it was from me moving it all around for the valve adjustment, but you only have 350 miles on yours. My left one seems fine.
