04-28-2020, 04:05 PM | #1 |
Max volts the charging system can take?
Hi All,
Thought I would post this here since it has the most traffic. I have pretty much smoked another battery trying to start my Apollo 250 with what I thought was just a dirty carb but really turned out to be a faulty CDI. This was a relatively expensive Kenitik lithium battery. This may be a stupid question so please bare with me with since my knowledge on motorcycle electrical is lacking. Could I theoretically use one of my Dewalt 20v 5ah packs as the battery with out smoking the whole thing? Electrical components can typically take more than the rated volts but I am unsure here. I have seen these packs used to jump start cars. |
04-28-2020, 04:20 PM | #3 |
Not a good idea but at least you were smart enough to ask. No question is a dumb question.
04-28-2020, 04:22 PM | #4 |
Thanks gentlemen!
04-28-2020, 07:22 PM | #5 |
You can diasy chain a car battery to the bike battery with jumpers to boost the starting amps. Just don't have the car running. I had to do that with my Hawk when my firat battery took a crap.
04-29-2020, 03:13 PM | #7 | |
In truth, I have had way better luck bump starting a dead Hawk than kick starting one.
04-29-2020, 03:18 PM | #8 | |
I am your average guy goes to the gym etc. and this thing tries to take off my leg off every time I give a go, probably due to the no compression release. Even the starter struggles once it gets to the compression stroke, to the point I have to let off the and retry or it will just stall and fry something. That's how I fried my first battery! |
04-29-2020, 03:22 PM | #9 |
That sounds to me like the battery was already weak to begin with. I have higher than normal compression on my bike and the YTZ7S style battery I have will crank it over just fine without stalling, except when it has a weak charge.
04-29-2020, 05:02 PM | #10 |
Yeah except it has always behaved this way even with brand new batterys.
Not sure why, I went as far as to upgrade the cable to the stater with 10 gauge and got a new solenoid. There was no change. |
04-30-2020, 04:17 AM | #11 |
my battery was dead for 8 months. kick started every day no problem.
04-30-2020, 07:50 AM | #12 |
did you upgrade the ground and battery cables to the starter solenoid and starter as well? it could be a bad cable there causing high resistance, or a bad connection causing high resistance...
04-30-2020, 09:22 AM | #13 |
I did using 10 gauge cable. That was one of the first things I did after reading up on it here. I'll try to take a video of it once I get it started.
04-30-2020, 11:12 AM | #14 |
10 is a bit light for the starter application, its rated for up to 85a for under 4ft runs, if i were doing a battery cable on my bike, i would go 8ga minimum, probably 6, given i have easy access to all sizes of wire working at a small engine shop ( i have several feet of 4-8ga in my tool box...LOL)
8 ga would bump you up to 150a handling... that may well be the issue right there, along with double checking your grounds are good and clean, and TIGHT on all cables.... |
04-30-2020, 11:48 AM | #15 |
as others have mentioned make sure your connections and your ground cable are good ....the stock ones are so so often.... and I also found on my TBR seven the stock battery was hardly sufficient so I purchased a new one
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 |
