Old 12-01-2013, 03:00 PM   #1
thefinkid   thefinkid is offline
Head Scratching baja 250cc carb info badly needed
hi guys. I'm new to the site and hoping to gain some good info on my bike.
I've got a baja 250cc. doing some work to it at the moment to clean it up and have it running sweet for next summer.
I've hit the first problem- after disassembling the carb to clean it and reassembling it, it is leaking fuel. the float valve is not blocking the fuel feed when the cup fills. so what i need now to solve the problem is an exploded view or a diagram for the carb to ensure i have everything in the right place.
Would anyone here have such a thing or a link to where i might find one.
Thanks in advance
Old 12-01-2013, 07:01 PM   #2
katoranger's Avatar
Welcome. My guess is it a keihin clone carb.
Weld is going to suggest buying a $40 mikuni carb.
Old 12-02-2013, 01:12 AM   #3
I might suggest that.
Old 12-02-2013, 09:39 AM   #4
katoranger's Avatar
I just saved you the trouble.
Old 12-03-2013, 07:04 AM   #5
Thanks lads, that looks spot on.
hopefully there will be no need for the $40 carb but i will find out over the weekend.
I'll keep you in the loop if the problem persists.
Cheers
Old 12-03-2013, 02:40 PM   #6
katoranger's Avatar
Pretty much a honda xr200 carb, but may use different jets. I bought a new carb for less than the parts to repair an xr80 carb.
Old 12-17-2013, 09:52 PM   #7
Thanks for the info lads. Carb is now running perfectly.
Discovered a random washer preventing the float valve from
closing fully.
Next job is to tackle the wiring as the previous owner
made a hack of it. Any wiring diagrams would be
a huge help.
Thanks again
Old 12-17-2013, 10:02 PM   #8
wiring
[ the wire colours may be wrong.. but follow the wires and it will work
ABIBABA ATV ETC
