07-02-2018, 10:07 PM | #1 |
Hawk Headlight -
I am getting annoyed by my headlight, it seems nearly impossible to aim properly (the screw wants to strip very easily) and the pattern is less than optimal. i know some folks have installed a fanless LED bulb, any leakage or water seepage around the bulb with that install ?
another issue is that light shines up form the edge of the glass directly into your eyes i am sure I could solve that by putting a piece of tape over it but it seems like a bad design. has anyone explored other headlight options ? a projector style would be pretty awesome. |
07-02-2018, 11:52 PM | #2 | |
Tape or weather stripping is a good way to block the light in that gap on the top if it bugs you. As far as leakage, i had no issues on my last Hawk, and it wawas ridden in, and parked in, some pretty heavy rain storms.
07-03-2018, 07:36 AM | #3 |
I have the LED bulb and no issues with water. I have a piece of foam weather striping between my windshield and cluster that blocks the light.
07-03-2018, 01:52 PM | #4 | |
It sounds like the lens is in the housing upside down. Those bolts and stuff could be replaced with better stuff. |
07-04-2018, 09:51 AM | #5 |
Thanks for the replies - Weatherstripping is a great idea, I think I am going to go with some upgraded hardware (different adjustment screw) and an LED headlight bulb.
I recently saw a Ledur LED aux handlebar etc mount in action, how well will the mag keep up with the load of accessories , even LED’s ? |
07-04-2018, 12:58 PM | #6 | |
Hawks have an AC to DC charging system. Not a magneto set up like the old bikes. There is plenty of power to run LED add-ons and a power port for cell phone charging or GPS. I wouldn't add any more than that. A voltmeter would help to let you know when you're running off battery and the charging system isn't keeping up. I have them on all my bikes that I have added power accessories too. |
07-04-2018, 10:01 PM | #7 | |
07-05-2018, 12:37 PM | #8 |
You're welcome. Happy to lend a hand or info.
