12-03-2016, 02:42 PM | #1 |
Oil level check Help. bashan 250
Just got 1 of my 2 new bashan storm 250. I have changed the oil and filled it back up with rotella 15w-40 so the oil is almost to the top of the oil check window with the bike level. Is this correct? I see the manual says to check the oil level on the dip stick with it leaning onto the kick stand.
Can someone know what way is correct? THANKS FROM A NEW OWNER. |
12-03-2016, 02:54 PM | #2 | |
12-03-2016, 06:52 PM | #3 | |
12-03-2016, 10:37 PM | #4 | |
Don't over think it. it would ,however be fine even if I weren't perfect, the thing will run practically dry while climbing telephone poles. Designed to run practically empty using neglected , thick dusty oil.
oil change ? |
