Old 09-14-2011, 01:12 PM   #1
rotax583   rotax583 is offline
t2 keeps killing battery's
hi,I have a rebel t2 that keeps killing my battery.it will last for a day or 2 then nothing.I unplugged all the lights and it still does the same.any help would be appreciated.thanks
Old 09-14-2011, 09:08 PM   #2
Disconnect the negative battery cable, connect one lead of a multimeter to the cable and the other to the battery. Set the multimeter to VDC, turn the key on and see what the reading is (should be near zero). If you have a high reading, try disconnecting the large red wire that goes from the battery to the solenoid (disconnect at the battery). Let us know what happens.
