Old 02-28-2022, 11:26 AM   #1
Nospark   Nospark is offline
2021 TBR7 Tire Pressue
If I converted the information from the owners manually correctly, the manual recommends 38 psi front and 40 psi rear. I will be riding almost exclusively on the street when I get this chick magnet assembled.
is 38F & 40R in the ball park of what others are running?
Old 02-28-2022, 12:37 PM   #2
I run both the Brozz and Titan at 20psi, that way can transition from offroad/gravel to pavement and still be ok
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Old 02-28-2022, 12:56 PM   #3
20psi is a good size disparity from 38 - 40psi recommended, assuming my #'s are correct. My interest here is simply to be sure I'm in the safe range for the street. I'm not familiar with motorcycle tires.
Old 02-28-2022, 09:47 PM   #4
Magician16   Magician16 is offline
If I was traveling all highway, I might get as high as 30 psi. I usually run 20 to 24.
2018 Bashan Storm(sold)
2016 Magician 250
Old 03-01-2022, 08:16 AM   #5
Those OEM Yuanxing dual sports tires are decent tires, and the same ones that came on my Storm. 20psi is a good idea for off road use as long as you don't get to rambunctious hitting rocks! But on the highway, you will see excessive wear developing on either side of the center of the tire since the center of the tire will be soft.
This happened to the front tire on my Bandit when previous owner ran it low for at least 500 miles. Destroyed front tire at 4000 miles!
Old 03-01-2022, 08:25 AM   #6
Thanks for the feedback. Looks like the manual stated pressure is higher than what most are running. I'm going to back 'em down to 30psi and see how that feels and looks on the road as a starting point. I understand the lower pressure, 20psi, for off road would make sense.
Old 03-03-2022, 03:30 PM   #7
Countrytour   Countrytour is offline
I weigh 180lbs. Running 38 f+r on the road, to get that extra 1mph. I was running 20 off road but dinged a wheel on a rock, 25 seems to keep the rim safe.
Old 03-03-2022, 04:13 PM   #8
TxTaoRider   TxTaoRider is offline
The factory tbr7 tires are pretty thin and not much sidewall stiffness so you'll need a little more pressure.
I think I was running 28lbs on mine. With my current tires I run 15 off road and 20-28 on road depending on if it's back roads or long higher speed blacktop.
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
