12-13-2016, 03:41 PM | #1 |
I weighed mine
So being retired means I have some time on my hands. I decided to run down to a certified scale and have my bike weighed. I filled the tank so it's a fully wet weigh. I removed all the stuff from my tool tubes and hard cases. The bike is a 2016 RX3 with the following farkles added and on the bike which attribute to the weight:
CSC Skid Plate Quick Oil Kit Kit Genssi LED Headlight Center Stand SAE Power Plug Coax Power Plug 2xUSB/Cig Pwr module Volt/Temp Disp that plugs into cig plug x-grip RAM mount Phone mount, arm and base RAM mount base, arm and holder for Spot Gen3 Capacitive Stylus Dual 10W Spotlights SpeedoDRD Hyperlites brake lights Billet Covers - Brakes, headlights, radiators Sintered Front Brake Pad 13T / 45T Shinko 244s Side Stand Pad Tourfella Hard Luggage 2 x Agri Supply Tubes DoubleTake mirrors Dragon Badges Wrap around handguards The bike weighed exactly 420 pounds. At home I have a digital scale and weighed each piece of luggage so I could get just the bike weight also. Left and right panniers are 12.5 pounds each and the top box is 12.6 pounds. That means the bike wet with the farkles weighs 382.4 pounds. Claimed dry weight is 385 pounds 1.7 quarts of oil is 7.2 pounds per gallon = 3.06 pounds 3.7 gallons of gas is 6.073 pounds per gallon = 22.47 pounds 67.6 ounces of coolant is 6.5 pounds per gallon = 3.47 pounds Wet would be = 414 pounds. That must include the OEM skid plate, crash bars, luggage racks and plastic luggage since mine was 420. with the farkles. Neat. Not sure if useful...but I'm a retired nerd and I like this kind of knowledge. Farkles: CSC Skid Plate, Quick Oil Kit, Genssi LED, Center Stand, SAE Plug, USB/Cig Pwr, Volt/Temp Disp, Phone mount, Stylus, Spotlights, SpeedoDRD, Hyperlites, Billet Covers, Sintered Brake Pad, Tank Bag, 13T / 45T, Shinko 244s, Side Stand Pad, Tourfella Luggage, Agri-Tubes, DoubleTake mirrors, Dragon Badg
2017 BMW F800GS Adventure |
12-13-2016, 04:39 PM | #2 |
Good work, Martin.! I'm a working nerd, and still enjoy useful knowledge to bore my family with. So many people get caught up in the weight issue, which unless it's obscene (I'm still talking bikes, here) is not a huge factor for me. It's nimble, and it rides so nicely, I have no complaints, and would recommend this bike wholeheartedly.
12-13-2016, 05:20 PM | #3 |
Hi Joe,
I weighed mine, too....but not as methodically as you: http://www.chinariders.net/showpost....5&postcount=11 Here's some more RX3 trivia for those of you that are snowed in... The site hasn't been updated in a year and a half....still has some interesting data: http://www.rx3adventure.com/rx3_weight.html jb
12-13-2016, 07:15 PM | #4 |
I've been through that site and was actually trying this morning to get this detail but the site was down. Back up now so I could use of of it's data and combine mine:
1.7 quarts of oil is 7.2 pounds per gallon = 3.06 pounds 3.7 gallons of gas is 6.073 pounds per gallon = 22.47 pounds 67.6 ounces of coolant is 6.5 pounds per gallon = 3.47 pounds 3.06+22.47+3.47=29.0 lb of liquids Wet would be = 414 pounds. That must include the OEM skid plate, crash bars, luggage racks and plastic luggage since mine was 420. with the farkles. Weighed Items- Grab Rail: 5 lb Rack Plate: 3 lb Rear Luggage Carrier assembly: 8 lb Updated CSC Skid Plate: 3 lb Passenger Foot Pegs (2): 2.25 lb Engine Guards: 12 lb Billet Guards - 4 lb Spot Lights - 1 lb Spot and Phone Mount - 1 lb Electronics - 1 lb Agi-Tubes = 3 lb Tourfella Luggage = 12.5+12.5+12.6=37.6 lb 5+3+8+3+2.25+12+4+1+1+1++3+37.6=80.85 lb it total farkles Totals- Wet Weight of my bike with all farkles = 420 lb Dry Weight of my bike with all farkles = 420-29=391 lb Naked Dry weight = 420-29-80.85=310.15 lb Naked Wet Weight = 310.15+29=339.15 lb
12-13-2016, 07:29 PM | #5 |
It's those sintered brake doovers. Sinter actually multiplies the gravitational pull. It's a fact. I read it on the intertubes.
Also that air in the Forevergreen state has a higher water content. All the you-midity adds weight. Fill your tires with ethyl alcohol instead, it's lighter than water. Don't forget the unmeasured weight involving the farkles that use electricikles. Even when they're not turned on, the electrons sit inside and those are sub-atomric particles. Every one knows that sub-atomrics makes the gravities stick together so they get heavier. If you poke some holes in the insulation those electrons can run out and will go to the nearest solar cell. That will bring the weight down more. Also fill your seat foam with hydrogen. Hydrogen is an anti-gravimator. It floats. On everything. |
12-13-2016, 11:49 PM | #7 | |
The "smoking" thing,,,, California voters passed the bill, but doesn't go in to effect for quite some time. Maybe 2018. |
12-14-2016, 12:32 AM | #8 |
If I poke holes in the insulation the pixies will spill out and could possibly be hurt. We can't have that!
12-14-2016, 10:34 AM | #9 | |
