01-28-2018, 04:01 PM | #1 |
Battery
I got my son a 110cc coolster pit bike and it seems the battery always needs to be charged is this normal? it starts fine but if he rides it for 45min or so and shuts it off, the battery is dead. Suggestions? Thanks
01-28-2018, 06:20 PM | #2 |
Welcome psey. Put a meter on the battery while it's running to see what voltage you are getting. It should be around 14v. If not, something's wrong with the charging system. I've found that it's usually the rectifier/regulator. If you are getting the correct voltage then it's probably the battery. You didn't say if it's new or not but sometimes that doesn't matter as the vehicle often sits for a while before it's sold.
01-29-2018, 10:59 AM | #3 |
Welcome!
I'll add to David's comments that the stock batteries are generally quite poor. I've had good luck with the Walmart AGM batteries.
01-31-2018, 03:18 PM | #4 |
Thanks, Ill do that and let you know. I do have a feeling it may be the charging system. When we first got the bike I hooked it up and something started smoking. Than I realized like a asshole I cross wired the batterie (i.e. neg on pos) but after I switched it the bike started and has worked fine ever since. The piece that started smoking is attached to the wiring harness. It may be what charges it i'm not sure. Its my first pit bike.
02-01-2018, 10:08 AM | #5 |
Please show us a pic of the device you speak of. I'm betting it's the regulator. BTW, you're in good company around here; several of us have done stuff like that.
02-06-2018, 08:36 PM | #6 |
Ok good, glad I’m not the only one haha. Anyway here is a pic.
02-07-2018, 10:58 AM | #7 |
That's definitely a regulator. Buy a new one and see if that solves the problem. It may also be referred to as a reg/rec or regulator/rectifier on eBay. Make sure it's identical.
02-07-2018, 12:01 PM | #8 |
Ok thanks! I’ll grab one and see how it goes.
03-04-2018, 03:34 PM | #9 |
So I called and told them what I needed. They procedded to send me a new starter and ground wire. All I need is the voltage regulator. Sent a e-mail so hopefully a new one will be on its way soon. Not sure why they sent a starter. bike starts fine just won't restart after shut off. Battery dies.
03-04-2018, 03:35 PM | #10 | |
I have not put a meter on it, but have used a new battery and the same thing happens. Should just be the regulator. |
04-03-2018, 10:29 AM | #12 |
Glad to hear that's resolved.
