Old 04-17-2021, 04:55 PM   #1
Ugly   Ugly is offline
'85 xr200r lifan 200cc 163fml wiring harness
I just started getting the engine mounted (took some creativity!) Now I need to get a carb and wiring harness! What are some good and also cheap(ish) options. There isn't a ton of room for the carb so the slimmer the profile the better! Thanks y'all!
Old 04-17-2021, 06:54 PM   #2
franque   franque is offline
If it's truly an '85 XR200R, vs. an XL200R, it was designed for a different engine, you might want to reconsider how you mounted it in terms of spacers, etc., unless everything is lining up (for carb fitment and do on). The '84-85 were designed to use a 4-valve RFVC motor.
You could get a PZ30B carb, and as for the harness, it depends on how much is still/already there. If you've got complete switchgear/portions of the harness, it might make more sense to get a used Honda harness and replace and adapt to the motor.
You could get a Chinese generic dirtbike harness, but there's no guarantee that the generic switchgear would directly fit up to it, so basically no matter what, some level of adaptation will be necessary.
