04-28-2020, 04:55 PM | #1 |
broken starter gear?
Have any of the nc250 guys broken a starter gear?
I broke the gear on my GPX. I say broke because I have abused the starter in every imaginable way. The gear in question is the one that the starter meshes with. It has very fine teeth and the teeth started popping off. As I was sourcing new parts I noticed that Zong has apparently reduced tooth count with corresponding lager teeth on the new production. A part change like that makes me wonder if it was a wider problem. Found a few of the teeth in the crankcase around the clutch and the rest were stuck to the drain plug magnet. Replaced gear and starter to be safe. |
04-28-2020, 07:24 PM | #2 |
Have not heard of this being a problem in the USA RX3.
How do you "abuse a starter in every imaginable way"? Just wondering what your circumstances where.
Live Zong, and Prosper |
04-28-2020, 08:44 PM | #3 |
The RX3 and RX4 have an automatic compression release so the starter is not working nearly as hard as an engine without the release. Not sure how your engine works.
04-29-2020, 01:26 PM | #4 | |
I actually think I have your broken cases in my shop. |
04-29-2020, 01:33 PM | #5 | |
In general I think dirt bikes are just harder on the starters than a street bike. I just thought it was interesting that Zong updated the design. |
05-01-2020, 01:00 PM | #6 |
It's nice to see they're still doing R&D.
Mrs. 2LZ had a first year Saturn. I worked on that car relentlessly (it broke continuously) and every part I replaced, had been redesigned.
05-02-2020, 02:40 PM | #7 | |
05-03-2020, 02:13 PM | #8 |
I don't think he's using the starter to propel forward; rather, bike stalls and while still in gear it moves backwards, rotating the whole engine back and thus engaging (and straining) the overriding clutch and related gears up to the starter motor.
05-03-2020, 04:49 PM | #9 |
Abuse as in I use the starter with the bike in gear to drive the bike through particularly difficult sections, no neutral or clutch safety.
Looks like he is using the starter to move the bike when the going gets tough. |
