Old 08-12-2011, 11:52 AM   #1
IPACA9   IPACA9 is offline
ATA-250D Clutch lever on engine
Picked up another Tao Tao ATA-250D from a guy for $200. I already have an identical one so this one was really intended for parts however I started to play with it. Got the carb cleaned out and it fired right up. The clutch cable was ruined so I picked one up from a guy around the corner that sells all the parts for the chinese atvs. I have discovered that there is no real "spring" to the clutch lever on the engine casing. I've never tore into a clutch before. Anybody have any knowledge of these. It will hard shift through the gears but I know that's not good...lol Is there some sort of spring or something needed for this lever inside. This thing runs like a champ so now I'd really like to just make a roller out of it.
Old 08-12-2011, 01:43 PM   #2
katoranger's Avatar
The "spring" is really the clutch springs in the clutch pack under the cover. When you pull the lever on the case you are compressing those springs.
