09-26-2019, 08:50 AM | #1 |
hawk replacement battery
straight to the point. Id like a new battery for the hawk. i see a lot of outdated/unavailable batteries from old threads or batteries that need extra foam or spacers. Are these our only options? Id like a Plug and play amg maybe. what are yall thoughts?
To light a candle, is to cast a shadow.. |
09-26-2019, 01:31 PM | #2 | |
The posts are opposite of the original, but works great.
09-26-2019, 05:04 PM | #3 |
The factory Hawk battery is not a common size. That is why you see foam spacers being used with smaller powersports batteries. I have a ytz7s style battery in mine. Double the cranking amps of the original battery and it works just fine, but yes it required foam blocks to take up the space.
09-26-2019, 06:27 PM | #4 |
how long are you guys getting out of your batteries? I recall life expectancy on my old Panterra was about 9 months before they died. I figured it was a combination of heat and vibration that did it.
09-26-2019, 09:33 PM | #5 |
A Drop in replacement for the chinese battery is the Yuasa 12N9-3B
https://www.amazon.com/Bater%C3%ADa-...sr=1-2-catcorr Yes it's an old school battery, is not gel and doesn't have any other magical property. Just an old school acid battery, i been using it for almost two years and it works just fine. I even activated it with the acid. |
09-26-2019, 09:34 PM | #6 |
Typical life span of a small poweraports battery should be 2 to 3 years, but that can depend on a variety of factors.
