05-09-2022, 12:57 PM | #1 |
Carb newbie - nibbi pe30 questions
Hi Everyone!
So I’ve scoured the forum. Tons of great stuff! I used forums to teach myself so much it isn’t even funny… Haven been able to find a concise answer to the following RE initial jetting of the PE30… please give me your input. I live in SE Florida… zero elevation… never gets cold… Where should I start with the jetting? Whatever the consensus is here I am going to start with. MODS are exhaust and I have the NIBBI pod filter. Where should I start with the following at zero elevation: MAIN JET - PILOT JET - NEEDLE POSITION - AIR / FUEL KNOB - IDLE KNOB - You help is appreciated. Want to get the carb on tonight. Thanks, Jon |
05-09-2022, 01:35 PM | #2 | |
Still new to it all myself so this is just my knowledge and experience on it, most of these guys on here definitely know more, but I felt like I should share! Hope you figure it out, brother.
2022 X-Pro Templar X 250 |
05-10-2022, 02:23 PM | #4 |
My own personal recommendation. Use a smaller carb unless you plan to go full cam, ported head, high compression, exhaust. Even then, the PE30 is a touch on the too big side. With a 70mm cylinder added it really starts to come into its own, but the PE28 as a whole is just a much better match to these engines.
Want proof of that. I have a PE28 with every mod named above and my jetting is actually smaller than the above persons with a PE30. I run a 38 pilot and a 135 main jet. He doesn't make more power than I do. His engine can't pull enough vacuum on the PE30 to draw sufficient fuel, so the jets all have to be bigger in size to compensate. This also makes the carburetor more sensitive to changes in altitude density, which means it will need to be adjusted more often to compensate for changes in climate and weather. I ran a PE30 for a while, so I am very familiar with the benefits and shortcomings. I actually got so tired of the carbs tempermental nature that I swapped back to a PZ30 carburetor until I got my PE28FL. The PE28, out of all the carburetors I have tried, is the best one of the bunch in my opinion. This is out of VM26, PZ30B, VM30, PE30, PWK30 and PWK32. I literally have a small box filled with carburetors from all of my experimenting. Want to know a fun truth. The PZ30 and VM26 clone are actually more than sufficient enough to support upwards of 20hp, which is more than most of these engines will ever make even with most of the upgrades.
05-10-2022, 06:39 PM | #5 | |
Our Templars have a 72mm bore so I’m really curious to see some of y’all modding madmen get into it lol
05-10-2022, 10:20 PM | #6 | |
In warm zero elevation Florida where do you recommend I start with the jets, air/fuel, idle and neddle settings? |
05-12-2022, 12:26 PM | #7 |
Considering the guy who asked the question has a Hawk... I would think it would be obvious.
05-12-2022, 07:10 PM | #8 | |
05-12-2022, 07:40 PM | #9 |
Pe28FL is flanged the same as stock so I use the stock manifold
05-14-2022, 03:29 PM | #10 |
And I bet being flanged like the OE carb, you don't have fitment issues with the angle or length of the manifold, causing the carb to be too close to the frame.
I'm thinking of moving the PE28 on my ZS190 over to my hawk, and putting a PWK28 onto the ZS190. The PE30 works, but damn is it moody with any change in air temp or humidity. Interesting in selling your PWK28, Dan? |
05-14-2022, 03:34 PM | #11 | |
As for selling the carbs I have, nah, I like to hang on to things. You never know what other bad ideas I may have
05-27-2022, 03:45 PM | #13 |
A lot of this info can be found on tbr7.com/upgrades/fuel-system
including a chart with a good idea of where to start with your jetting depending on elevation, mods, and carb type. |
