04-09-2023, 03:46 PM | #1 |
Bashan Storm 250 - Sprocket Set Up
Hey guys. I bought a used Storm and as a result, I don’t have a manual and I’ve been struggling to do the things I want to do to this bike. I was hoping someone could help me out with a decent gearing setup for highway/long distance use. I don’t REALLY plan on taking it anywhere too far but I want the maxed out best set up for top speed. I live in Phoenix and as of right now I feel it’s dangerous to even ride in the slow lane here because of how slow this thing is (I love it, but it does need a few more mph). Any help would be much appreciated!
It’s currently stock as far as I can tell, I plan on rejetting up to 115 for the main jet and putting a slip on on it, possibly upgrading the air filter. Might go up to 120 depending on how that does. I’m very new to all this. |
04-09-2023, 04:27 PM | #2 |
I rejet the OEM carb. Works fine.
Regarding the rear sprocket, JTR279 fit my storm, but I would verify those dimensions just in case they have changed the rear hub: http://www.jtsprockets.com/catalogue/part/JTR279/ Here is a thread on the sprockets https://www.chinariders.net/showthread.php?t=30749
04-09-2023, 04:29 PM | #3 |
In addition to rejetting the carb, I removed the cat and drilled the muffler for more flow. This makes a difference in the torque and power. You will have to port the head for the next level if you still want more
Here is my thread on the exhaust: https://www.chinariders.net/showthread.php?t=30235 Look at post #17 for jetting. #34 to #38 on the pilot #105 to #115 for the main jet This is a good set up for me at ~800 feet above sea level A thread on the jets: https://www.chinariders.net/showthread.php?t=30694
04-09-2023, 04:52 PM | #4 |
Tusk DSprot
Big and badassed knobby. I can't believe that this tire fit, but it does, no problem:
https://www.chinariders.net/showthread.php?t=31897 more: https://www.chinariders.net/showpost...5&postcount=17 https://www.chinariders.net/showthread.php?t=26859
