09-18-2019, 03:31 PM | #1 |
Rim/Tire sizes
Is it easy to swap out front and rear rims with larger? I will be getting 17/19 on my Brozz but was wondering about keeping a spare set of 18/21 with more aggressive tires for a little better off-road experience for those times when you want to do more off-road than on-road. Thank you. Mark
09-18-2019, 04:14 PM | #2 |
Depends on which version of the Brozz you have as to what your options would be. Blue Eagles could most likely use the tt250 wheels with little to no fuss. Otherwise, ordering another set of wheels, or if possible just hubs and then working out a set of spokes for larger rims. If you have a normal Brozz you can use a Hawk front wheel, but you would have to lace up a separate rear drum hub.
09-18-2019, 07:04 PM | #3 |
I have the 2019 which I think is the same as the Blue Eagle. You think the TT250 wheels would fit? I may have to look into that. Thank you Megadan.
