07-22-2019, 07:11 PM | #1 |
[Apollo 250] Clutch lever too loose
Hi all, I'm new to pit bikes and I'm having trouble with my clutch lever. My dad was riding it and fell, and it slightly bent the clutch lever and now the entire clutch cable is loose. I cant seem to figure how to tighten it. I've tried adjustments near the lever arm as well as the at the handlebars. Any insight is much appreciated. I have a feeling it's something simple but I cannot figure it out after 2 days.
I have also tried tightening the flathead screw on the assembly and it does nothing. My lever is loose to the point where it can be moved up and down. |
07-22-2019, 07:43 PM | #2 |
He more than likely either broke or kinked the cable.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 07-23-2019 at 08:27 AM. |
