Old 08-31-2019, 09:07 PM   #1
MotoJoJo   MotoJoJo is offline
Spacer for front wheel
Bought my 2017 hawk second hand and it seems to be missing a spacer in the front axle. Either missed in the original assembly or not shipped with the bike. If the axle is tightened the disc rubs. If it's loosened to where the wheel spins properly it's not tight at all. Anyone know where I can find only the spacer without buying a new wheel assembly? Or one sold for a different bike that's the same size? Perhaps a Honda?
Old 08-31-2019, 11:32 PM   #2
NzBrakelathes's Avatar
Old version Bashan.
www.brozz250.com
you can see the banner above as they sponser
Old 09-01-2019, 07:11 PM   #3
Thanks
That's lovely it's called the shaft sleeve, on a related note do you know If the rear cargo rack matches bolts with the hawk?
Old 09-02-2019, 07:49 AM   #4
I have the rear cargo rack - 3 sizes!
From $30 to $40 posted to the USA
Or if you want to use Ebay its more expensive and only the mid size listed
Old 09-02-2019, 09:50 AM   #5
franque   franque is offline
Try switching which side the spacers are on, assuming it still has two? Sometimes they get mixed up.
Old 09-02-2019, 11:27 PM   #6
Here’s a clear vid showing the Bross rack etc
Answers your question?
Old 09-04-2019, 11:53 AM   #7
It seems to only have one. The sites that sell the full wheel assembly only showed one
Old 09-04-2019, 11:56 AM   #8
Should have one spacer on the rotor side.
2020 Kawasaki Vulcan S
Old 09-04-2019, 02:30 PM   #9
I'd give RPS a call, and either have a local machinist turn one up (if you can get specs from them), or just order one from there.
Old 09-04-2019, 07:30 PM   #10
Peace sports in Atlanta I would say has what you need
