05-17-2017, 05:31 PM | #1 |
Swapped Air box for Uni filter - Hawk 250
Originally I had clearance problems with my aftermarket exhaust and airbox, so I ordered a Uni filter and pulled the airbox out. Here's my experience so far:
When I had the exhaust in the correct position, it pressed on the airbox and even with heat wrap, it melted the bottom corner of the airbox. With the exhaust pushed down to avoid the airbox, the muffler rubbed the outside tire knobs when the rear spring was compressed. - I ordered a Uni Filter (https://www.amazon.com/Uni-2-Stage-A.../dp/B000WJIX6W) which is slightly too big at the coupling, but still works. - The airbox was tough to wiggle out of place and by removing it, I lost the rear inner fender well, which gives protection to the turn signal beeper, the CDI, the back side of the battery and the underside of the seat. If I keep this setup, I will have to fab up a new inner fender well or riding in the rain, water or mud might be a problem. - The new filter doesn't fit behind the plastic panel. My filter has a 15 degree offset and still is compressed by the plastic panel. - The intake noise is MUCH louder than before and almost drowns out the exhaust (at least from the seat). - After the swap, it was running lean at WOT and I swapped out the 115 main in the Mikuni for a 120. - I accomplished my goal because the exhaust is up higher where it should be. However, it opened up some other things to put on the to-do list. It runs well and I'll try it for a while before I decide to keep going with this or mod the old airbox to add clearance for the exhaust.
2016 RPS Hawk 250, exhaust, Uni Filter, Mikuni VM-26 clone w/ 120 main & 30 pilot, MSR shifter, 17/45 sprockets, JT chain, digital cluster... |
05-17-2017, 05:51 PM | #2 |
Looks great!
You need the "trash can mod". Solves the problems. Did you start solenoid hang on the left side of the air box too?
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 05-26-2020 at 12:24 PM. |
05-17-2017, 07:30 PM | #3 |
I am going to try and experiment with exhaust wrap and reflective gold heat shield on my hawks air box when I assemble it to see if the combination of the two prevents it melting. I bought a 2"x15ft roll and a 2ftx2ft sheet of it. I will definitely post on my success or failure with it.
If that fails I may look into a custom intake pipe to a large uni foam filter where the air box sits, and do some sort of inner fender like above, but try to seal it off. I want to shield the filter as best as I can if I go that route, but I would rather have an air box.
05-17-2017, 08:57 PM | #4 | |
Yes, my solenoid was on the air box. For now, I zip-tied it to the frame.
05-17-2017, 09:29 PM | #5 |
Looks good Bill....add in 2LZs trash can mod and you've got it licked
05-18-2017, 10:14 AM | #6 | |
The trash can didn't fare so well though. I got this one for about 5.00 at Lowes.
05-18-2017, 12:31 PM | #7 |
I switched to this pod filter a few years ago, and it has been terrific: http://www.ebay.com/itm/Angled-Foam-...5Y8X3s&vxp=mtr
05-19-2017, 10:39 PM | #8 | |
Thanks for the tip. Hope to work on it next week.
05-19-2017, 10:41 PM | #9 | |
05-20-2017, 10:52 AM | #10 |
What Foam Filter Oil did you use on your new UNI filter?
05-27-2017, 01:23 PM | #11 |
I use Maxima Fab1. It sprays on blue, so it's easy to see and it sticks like cobwebs.
05-29-2017, 11:08 AM | #12 |
I have a question about the pod filter mod, how doest it perform on rain? is it possible that water gets inside the carb? I'm asking this because here in Costa Rica rain gets wild, should I keep the stock box or is it ok to go with the pod filter?
Cheers. |
