Old 02-02-2010, 11:37 AM   #1
fishman10   fishman10 is offline
fishman10's Avatar
harbor freight score
If you haven't done this before these cheap float chargers are going on sale again 2-11-10 for $3.99, then cut the alligator clips off and add a simple male female connector available at most auto parts and truck stops,then you have a battery tender for $6.00.[IMG]http://i948.photobucket
Old 02-02-2010, 11:39 AM   #2
fishman10's Avatar
battery tender
woops hers the pic ....
Old 02-02-2010, 11:40 AM   #3
katoranger's Avatar
Where's the link?
Old 02-02-2010, 10:17 PM   #4
fishman10's Avatar
harbor freight
sorry ,i bought mine at a harbor freight in the nearby city,I will check out the online availability.
Old 02-02-2010, 10:20 PM   #5
fishman10's Avatar
float charger
here it is , but its not at the sale price till 2-11-10...http://search.harborfreight.com/cpis...rger&Submit=Go
Old 02-03-2010, 02:29 AM   #6
That's an excellent idea. Are you saying that you keep one end connected to the battery at all times, and then plug in the tender as required? If so, may I recommend that you change the configuration? What I mean is that the connector from the battery has one exposed terminal and one that is insulated; it would be best to use the insulated terminal as the positive connector, so it doesn't contact ground while you're riding.
The diagram depicts the exposed terminal as positive. Of course, it isn't critical if you have some form of boot that covers the connector when not in use.
Cheers!
Old 02-03-2010, 03:11 AM   #7
Wild_Alaskan   Wild_Alaskan is offline
Wild_Alaskan's Avatar
i would swap the connectors so the positive isn't exposed, if it shorts for very long than your battery will suddenly be totally dead for a while and can cause permanent damge. i found out the hard way trying to jump four wheelers connecting on cable the the negative side and one to the frame :oops: Battery never really charged right and could only turn the motor over for 5 sec before it was dead.
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470
400cc lifan build vid: http://youtu.be/20HoU8OK_Y0
other fun: http://tinyurl.com/wildalaskan
Old 02-03-2010, 08:44 AM   #8
fishman10's Avatar
float charger
yes ,i should have swapped them, The pc does stay on the zong and my harley all the time, for this one i did wrong i push a small pc of nitro rc fuel line on the exposed terminal,and it seems to fit real snug ,sometime i might change it ,but you get the idea for the price its a deal i have 2 of these set-ups and another one i left alone with the alligator clips.
