Old 12-23-2023, 03:41 AM   #1
warrenpeas   warrenpeas is offline
How can i run an oil temp sensor?
I really really do not want to tap the engine case to install the sensor if at all possible. But i cant install it where the oil drain plug is becaus i'm using that for the oil cooler. Is there a way to install the sensor inline with the oil cooler 'out" braided steel line?
Name:	Screenshot 2023-12-23 024021.jpg
Old 12-23-2023, 04:57 AM   #2
XLsior   XLsior is online now
XLsior's Avatar
I would not install any sensor near shift levers or around the skid pan.
I've contemplated installing one but if have installed an oil cooler already its running cooler than stock...and stock engines run reliably enough without a cooler...
the best temp sensor Ive found is just palming the side of the radiator. If I had to install a temp sensor i'd probably drill and tap the rocker cover. not sure if the make temp sensing unit small enough where it could bypass the rocker cover oring and sit inside the rocker cover cavity...
But long story short I stopped concerning myself with oil temp and just rode my bike till I overheated.
Old 12-23-2023, 08:01 AM   #3
My oil temperature sensor is mounted in the oil drain plug on the bottom of the engine. The sensor that came with my gauge replaced the oil drain plug.My skid plate protects it from any damage.
2020 Kawasaki Vulcan S
Old 12-28-2023, 02:53 PM   #4
Deckard_Cain   Deckard_Cain is offline
I use the same system, a Koso unit with digital gauge I got from DennisKirk.
OP says he's running his oil cooler to the oil drain... somehow ... for return? Seems odd to me.
Old 12-28-2023, 03:02 PM   #5
From the picture, it look like he is using the oil screen plug adapter.
Old 01-04-2024, 11:22 AM   #6
Agreed.. which adds to my confusion. There is still the main drain plug in the bottom of the case available.. they make tons of drain plugs with 1/8" NPT in them for oil temp sensors.
I'd just do that and be done with it.
Old 01-05-2024, 04:25 AM   #7
solidsnake2431   solidsnake2431 is offline
Sounds unessisary complicated. Why not something simple and easy like this..? That is what I got for mine
Old 01-05-2024, 04:41 AM   #8
That's a nice simple solution. But the head can be much hotter than the body. Maybe get both installed to keep track of the head too.
Or as XLsior sez, just ride the bike until you are overheated.
