05-11-2023, 07:12 PM | #1 |
Total engine failure Templar X
So, after re-reading all the info I could find, I found the intake and exhaust both a little loose. After tightening them up, it fired up with the carb set as all here have. The valves were re-checked and to spec. I then took it for a short ride to see how it felt. It had great throttle response and it was very smooth with little to no popping on deceleration. The speedo wasn't registering so I made a pit stop and adjusted it. Back out I went. I made it 1.9 miles from home and it was running awesome. All of a sudden, it stuttered and died. I ended up pushing it all the way home. It has no compression at all. It has the proper level of T4 15W-40 and the plug was a bronze color.
I have a claim in with the seller. We will see what happens.
Zooker 2022 Hawk 250 - Mikuni clone carb, jetted appropriately. Pro Tork CRF 150 pipe. Nibbi pod filter. Tusk Chub bars with riser adapters. Amazon levers and foot pegs. Typical gearing change for street... Acerbis hand guards. Nibbi grips. Shortened rear fender. No graphics 2022 Templar X - Stock carb rejetted appropriately, Nibbi grips, Amazon hand guards. Amazon seat cover. Acerbis skid plate, heavily modded. Shortened rear "fender". Custom graphic kit. |
05-11-2023, 07:30 PM | #2 |
That sucks! How many miles do you have on the bike? This is the first I've heard of such an issue and possibly a lemon from the factory
05-11-2023, 07:50 PM | #3 | |
I have approximately 3 miles....
05-11-2023, 08:02 PM | #4 |
Did you recheck the valves?
05-11-2023, 08:42 PM | #5 |
After the failure? Not yet...
Before the failure they were set to 2 and a half thousandth snug. The motor sounded great until...
05-11-2023, 08:54 PM | #6 |
If there was a mechanical failure, it will be one of 2 things. Either your piston now has a sunroof, or a valve failed. Or both, if the valve head broke off and became lodged between the piston and head.
If it was a valve, when you go to check them again you will find one of two things. Either one has a huge amount of valve lash as the stem bent and it can't retract, or endless amounts of no-gap as the spring tries to eject the stem out of the top of the head.
05-12-2023, 06:24 AM | #7 |
Keep in mind that this is a Zongshen engine, not a Zuumav engine. Wuyi Zuma, the parent company of Zuumav, is likely to rely on ZS to warranty the engine with a pass through arrangement, but would be subject to specific limited liability. If you look at Alibaba, these engines are low cost, and this would be especially true for contracted vehicle manufacturers that use ZS engines. Make sure that you document anything you do with photos of the engine.
05-12-2023, 07:02 PM | #8 |
Thanks Mega and Thumper. I hope to open her up tomorrow to get a peek in there. I will be sure to document everything.
I wonder if I could get that 300 cc liquid cooled motor in there?
05-13-2023, 10:36 AM | #9 |
So, I got a look and the locknut on the exhaust valve and the adjustment post backed completely off. I was able to fish the nut out with a magnet superglued to a long screw. I am going to look fora replacement locknut today and see if it will start. I cannot see any other issues at the moment.
Perhaps the exhaust valve was just not able to open and gave me the impression there was no compression??? I have had many bikes and this is a completely new one to me. I am usually accused of way over tightening things, but apparently did not this time. The intake valve is still in spec.
05-13-2023, 10:54 AM | #10 |
Good find, hopefully no damage.. use the ugga dugga method when tightening.. i don't bother with my torque wrench anymore these days.. i actually messed up a valve stem by trying to figure out the torque of the locknut with a torque wrench many years back as my bonehead move of that day
05-13-2023, 05:05 PM | #11 |
So, no go...
After getting the valve back in spec it still has almost no compression. Still waiting on a response from the seller.
05-13-2023, 06:12 PM | #12 | |
It's a good idea to make sure that the valves are adjusted so that they CLOSE (preventing blowby burnout-valve seats subsequently needing lapping). No gap can cause this, and these engines are often shipped with tight or no clearance. But on the other hand, if exhaust gases can't escape, this is a different problem (rings, head gasket). Or worse, if the tappet adjusts longer and the valve opens more and more, interference will happen as the valve hits the piston (as Dan mentioned above, and now XLsior mentioned it in the next post).
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 05-13-2023 at 11:17 PM. |
05-13-2023, 06:58 PM | #13 |
is it possible that when the exhaust valve lock nut fell off and the tappet adjustment screw had free will to either back off or tighten you had 2 outcomes...
1 the tappet tightened causing the valve to over extend forcing the it to kiss the piston warping it and damaging the valve/valve seat....loss of compression. 2 the tappet went lose not allowing the valve to not open sufficiently/remain closed to expel exhaust...damaged head gasket/piston rings |
05-13-2023, 08:22 PM | #14 | |
