12-28-2022, 11:22 AM | #1 |
Could ethanol blend be better for winter storage??
We went from unseasonably cold weather to unseasonably mild in just the past couple of days, and I intend to do a little riding. I want to top off the gas on my bikes, and add Sta-Bil fuel stabilizer before the next cold stretch, and I have been wondering if ethanol blend may be better, because it absorbs water, and with non ethanol water would sit in the bottom of the tank, and carb. It may not matter, but I was just curious. Thanks.
12-28-2022, 11:44 AM | #2 |
When ethanol absorbs water it will turn to gel. You want to avoid use ethanol fuel.
12-28-2022, 11:50 AM | #3 |
I use only premium gas in my bikes and lawn mowers, to avoid the ethanol in regular. Missouri has ethanol-free premium, as does Montana.
12-28-2022, 11:57 AM | #4 |
Here our ethanol free fuel is regular and is roughly 50 cent more a gallon than regular with ethanol.
12-28-2022, 12:50 PM | #5 |
I don't have a metal fuel tank so I am less worried about water, but corn jello setting up in the fuel tank isn't fun. My closest ethanol-free station is of all places Buc-Es. Never been there, and not all of them sell E0. It is far enough away I could not make it my new gas station, and the price they charge is 9% more than locally for corn glue fuel. But if I was winterizing a metal tank bike I'd make the effort to go get some E0 from them as buying it in a tin can at a store is extremely costly.
For now I put up with Sta-bil ethanol treatment and corn glue fuel in winter which I mix in a 5 gallon metal jerry can. Right now the price per gallon of Sta-bil treatment used in the 32 oz bottle and the price per gallon of Buc-Es E0 over a gallon over the local corn glue fuel gallon price is identical, so for me it is currently a wash. Gas Buddy is predicting Gas Prices to rise up to a national average of $4.36 next year, peaking by the end of summer. So I might be trying Buc-Es E0 if by then the difference in per gallon cost is higher than Sta-bil treating local E10. Search tool I used: https://www.pure-gas.org/
12-28-2022, 12:53 PM | #6 |
Our ethanol free gas is 90 octane, and is usually about $1.00 more than regular 87 octane at the pump. I just got back in the door from filling up with the 90 octane ethanol free, and treating the TBR7. I may take another down later, and do the same. It's still pretty cold on the legs at 55 mph, but not too bad. At least the riding coat is comfortable. I have the matching pants, but never wear them.
12-28-2022, 01:07 PM | #7 |
I never worry about ethanol in single cylinder mowers and pressure washers because they are so easy to empty the bowl on the carb or clean the carb. I would never use ethanol in my zero turn twin cylinder mowers, boats or my scooter. You are asking for trouble if you do.
12-28-2022, 02:14 PM | #9 |
Some of us live where the air hurts you in the winter time, and stuff is covered in ice.
12-28-2022, 03:26 PM | #10 | |
image uploading site The bike runs great, and the carb seems in good tune. The gearing must be stock, because it is geared really low. The knobby tires handle fine, but braking is not as good with them as the 50/50 tires. I have a bad habit of using my rear by itself at low speeds, and I found out that the knobby tires will skid easier. |
12-28-2022, 03:56 PM | #12 |
A freezer wishes it could get so cold.
