06-12-2021, 05:46 PM | #1 |
Ebay heated grips
I bought these cheap pair of heated grips and they work fine, but had problems with the throttle tube fit inside the throttle assembly (the new throttle tube slips and doesn't have a resting position because it has a smaller diameter).
The heated throttle plastic part where the cable slots in can be removed for adjustment (black plastic in 2nd picture) , so I decided to cut that same part from the old throtle grip (the white plastic bit) and super glue it to the new one and it now works properly. I hope this helps anyone having the same problem. |
06-12-2021, 08:06 PM | #2 |
I guess this is the time of year to get a deal on heated grips and apparel.
06-12-2021, 08:15 PM | #3 |
I bought these same ones for my Rhino. I was planning on installing them soon as part of my summer projects so this is a timely post. Thanks for the idea, pablordf!
grips, heated |
