jetting seems SO close, yet not quite
Got the Mikuni clone reinstalled on the Enforcer...
Running a 115 main and 25 pilot. Needle in the middle position. Ebay exhaust. Stock airbox. At around 900' above sea level. Have tested a few different settings with idle screw and fuel/air screw. Bike starts and idles just fine. Runs decent below half throttle, as soon as it gets to mid-throttle, it sputters and bogs. I don't have a tach, so I can't tell you exactly what RPM it stumbles at. It feels so close, but still off. I've read most of the threads here, but can't decide which way to go next. |
Keep checking your spark plug. The electrode insulator should be tan in color when the jetting is right.
I put in another plug and it ran much better, but this plug was brand new. I bought it last month when I bought the bike.
The stumble is still there. |
Make sure it isn't stuck at half choke. That fine til half theottle and then bog is exactly the issue you will run into if it is.
Also, that 115 may be a tad rich with a stock airbox. Have a 112.5 main jet?
Not at half choke. This is with choke off.
You think it's too rich with a 115? I was thinking it might be too lean, looking at the plug, and noticing the engine seeming pretty hot. I don't have a 112.5, I have a 110... |
#8 | |
The only other thing I can think of is the float height might be off. I only bring up the half.choke thing because it has bitten several members here, even me. Heck, I had the choke go to half on its own once when I hit a bump lol.
So I tried a 110 main. Bike ran EXTREMELY hot, and not well. Obviously lean.
Having already used the 115, I thought I would try a 120. No more stumble, bike pulls strong. Starts right up without needing choke. (this was with the 25 pilot and the needle in the fourth position from the top. However, idle was off - when I revved it in neutral, it wouldn't come back down, and it didn't idle well. Turns out I appear to have lost the retaining clip that goes in the slide above the needle. Argh. I have no idea where it popped off to in the garage. I may end up having to order a whole new carb if I can't find it... |
#10 | |
As far as needle cljps. https://www.amazon.com/MIKUNI-VM20-3.../dp/B003CJW4W8 Never hurts to have spares. ![]()
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 06-03-2020 at 01:59 AM. |
Not the C-clip. Isn't there another retaining spring thingy that goes above that?
Ahh, you are talking about the V shaped retainer. You should be able to just borrow one from the stock PZ30 carburetor. They may be called different names, but they share quite a few parts.
That's it! Thank you...
#14 |
#15 |
Still working on it. Didn't realize that I needed to plug off all the air box hose stuff with the new exhaust... It's getting closer.
