04-17-2020, 11:04 AM | #1 |
Keeway
Hi again Has any of you's heard of keeway superlight? as i have just bought one
and the only issue is tachometer is not working and neutral light wont come on. I have had a quick look and can't even find a fuse box. I am so confused |
04-19-2020, 11:51 PM | #2 |
Keeway = https://en.wikipedia.org/wiki/Qianjiang_Motorcycle Almost every mainland chinese bike mechanic knows QJ wiring are in weird colour coding/ jet # difficult translated to mainstream brand...
Counter balanced CG jammed to fancy body parts = Superlight Fuel injected OR good old tech? FI ownwer's manual said next to battery https://www.grupomultimoto.com/media...erlight125.pdf Carb version is a 10A fuse
04-20-2020, 10:55 AM | #3 |
thanks
thanks for the reply maybe i didn't make myself clear all my electrics work with the exempt of my neutral light and tachometer
04-20-2020, 11:09 AM | #4 |
I would check through all the connectors and make sure the pins are pushed all the way in and locked in place. I had a few loose on my Hawk. One was for the neutral light.
04-22-2020, 05:28 PM | #6 |
Chalk that one up as a win.
