10-25-2019, 01:29 PM | #1 |
2019 Brozz Gear Indicator
Just got done assembling my Brozz and everything works great except the display for the gear indicator isn't working. Just wondering if something easy or if I have to start tracing wires. Thanks.
FireDave 2019 Brozz 250 1982 Yamaha SR250J Exciter 1982 Kawasaki KZ 440 |
10-25-2019, 01:33 PM | #2 |
Check the connectors at the cluster and gear selector switch near the gear shifter to make sure all the pins are pushed in all the way and locked in place. Does the neutral light come on?
10-25-2019, 02:00 PM | #4 |
Thanks
10-25-2019, 03:09 PM | #5 |
I had a fuzzy neutral light going ON & OFF since new. I re-plugged the whole main wire harness no joy. Found a louse N wire under the front sprocket cover where it rubber bushings through into the engine case totally by accident when I pulled the chain for cleaning... I was bored. Point is start top down but you may get elbow deep into it but you WILL find it.
12V test light is your friend. https://www.harborfreight.com/612V-C...ead-63603.html
10-25-2019, 07:12 PM | #6 |
Mine didn’t work as well. I was getting crazy gears like 8th gear when I should be in 5th. Turned out there was a pinched wire in the cable down near the sprocket cover. In fact the cover crushed the wire bundle which was the issue. Peace Sports sent me a new gear selector sensor and it works fine now.
2019 Bashan Brozz 250 2019 Honda Africa Twin CRF1000L |
10-25-2019, 08:26 PM | #7 |
Sounds like the black wire where gear ind wires connect (6pin) has no 12v ign on.
Neutral doesn’t display at led part etc |
11-01-2019, 10:44 AM | #9 |
Lol, Yeah that usually helps.
