10-31-2019, 07:42 AM | #3 |
Also if you plan to assemble yourself.
TBR7 is a breeze... 90% assembled, slap a front tire on and some handle bars and you off to the races. Tons else to do in theory before you first ride... but, you can get on the road same day if you choose to shelf the changes ( valve lash, carb \ needle swap, loctite on nutz etc. ) |
10-31-2019, 12:20 PM | #4 |
I own the Tao Tao TBR7 2020 and the 2020 Hawk. The TBR7 has the same ground clearance as the Hawk. It has better performing brakes than my Hawk, it comes a lot more assembled. If assembly is a concern definitely get the TBR7! The Hawk is not hard to put together if you are mechanically inclined. But I wasn’t fond of the big bag of unlabeled parts you get from Hawk and your supposed to know where it all goes. Also the rear suspension is better on the TBR7 than my Hawk which is probably why most people change the shock on the Hawk.
That being said I can not attest to the Brozz or any other Chinese bike for that matter. All of that being said I love my Hawk and TBR7 equally for different reasons. The TBR7 is a way better bike for the street from the factory than the Hawk. but the Hawk I like better off road specifically because of the tires. Not the suspension, the Hawk bottoms out on a 2” deep pothole. How sad is that? Of course I am 6’1” and weight 240! I’m sure these bikes are designed and manufactured for someone 5’5” and 140lbs. The point is just get one no matter what you get you will find reasons to love it and maybe some things you would like to improve, every problem and fix are right here in the forum. No project too big or too small. Thanks to people like MegaDan And JerryHawk and Oneleggedrider way too many names to mention. |
11-02-2019, 10:59 AM | #5 | |
This bike will only see pavement on the way to the dirt so offroad is it’s main function. I build sidecars and bikes so assembled or not doesn’t really matter. Thank you so much for the reply👍👍👍👍👍 |
11-02-2019, 09:36 PM | #6 |
I'd look at the Orion RXB-250L.
11-03-2019, 07:22 PM | #7 |
So how close are you to purchasing a bike? Just curious you are in for so much fun.
11-03-2019, 11:56 PM | #8 |
Ready to purchase ASAP
11-04-2019, 10:46 AM | #11 |
Yes it does. If that bike would of been available 3 years ago I would of gotten one.
11-05-2019, 12:07 AM | #12 |
Let us know if you get one.
Btw, here's a good thread on Thumpertalk about them. https://thumpertalk.com/forums/topic...orion-rxb-250/ |
