Old 10-18-2019, 11:04 PM   #1
Choptop76   Choptop76 is offline
2017 taotao rhino
I have a taotao rhino 250 it will crank only by crossing solenoid but still will not start help
Old 10-19-2019, 05:09 AM   #2
Mudflap   Mudflap is offline
Does it have spark? If not the first thing I would check is the brake light switches.
Old 10-19-2019, 05:52 AM   #3
franque   franque is offline
Check the grounds, see if they're loose or corroded.
Old 10-19-2019, 09:14 AM   #4
Darth Racer's Avatar
I second what Mudflap has posted. The brake sensor on the TaoTao's is of very poor quality.
If you disconnect it and short the connector it will bypass it. I did it to mine temporarily... It's on permanent bypass mode now. My Rhino spends too much time in the water to be messing around with the brake sensor all the time.
