08-26-2019, 08:01 PM | #1 |
Bashan BSR Fender Eliminator
Decided to remove stock fender since it was bouncing and hitting the tire and save some weight. The install wasn't bad drilled a hole into the cross member, added washers and steel strap. I connected the bullet connectors with this kit I bought on Amazon.
This fender is very cheap so I took the LED housing apart and applied silicon seal internally for weather proofing. After the license plate is mounted, the fender only lasted 1/2 of a ride. The ride was rough the fender broke clear off at the license plate leaving my plate somewhere on the trail... Do NOT get this plastic junk if you are riding off-road!!! Anyone have a good metal fender to recommend?
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
08-27-2019, 10:03 AM | #2 |
Thanks for the heads up. Too bad it turned out to be junk. It did look nice.
