Old 05-12-2020, 12:52 PM   #1
zburns   zburns is offline
TBR7 and Knobby Tires
Still waiting for the machine to get here - but looking at some more aggressive tires for around the property. Anybody have any luck find knobby or otherwise more aggressive tires for this?
90/90-19 Front
11/90-17 Rear
Can't find much online that would work. But I'm considering changing out the entire front/rear wheels if I can find tires that would work.
Old 05-12-2020, 01:21 PM   #2
Rocket tests   Rocket tests is offline
Rocket tests's Avatar
Thr Brozz recon tires will fit the TBR7 wheels. If you are willing to buy a new front rim I'd suggest the hawk rim, the speedometer will actually read correct with the 21" wheel swap. The rear tire can be as wide as 130 so 110 is not absolutely required.
Old 05-12-2020, 01:40 PM   #3
OneLeggedRider   OneLeggedRider is offline
OneLeggedRider's Avatar
I'd buy a Kenda Trakmaster II for the rear and try to find out what company is making the front tire for the Brozz Recon.
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 05-12-2020, 07:44 PM   #4
Captcj68chris@aol.   Captcj68chris@aol. is offline
Hi all. I have a 2020 tbr7. I'm looking for knobby tires to. Can't seem to find the ones that are the stock size. Front trakmaster II come close, but I'm worried about the rear they all seem to be bigger. The swing arm has SOME room but I concerned about the muffler above, that looks like trouble.
Some one said they have full knobby on their bike here? If so what kind,sizes?
Thanks in advance
Christopher
