04-30-2019, 11:25 AM | #1 |
Apollo 250 db36 Air filter upgrade
Hello im new to this forum, how do i upgrade the stock air filter mounted on the front of the bike. I was under the impression that the air filter is suppose to be connected to the carburetor under the seat. I want air pod filter. How do i install it on my apollo 250. and which air pod should i use?
04-30-2019, 11:55 AM | #2 |
I think I have a 43mm UNI filter attached to my carb (PZ30/VM26 "30mm" size carb).
As for another filter mounted on the front of the bike??? Pics please... I don't have that style of bike and haven't seen many pics of said filter from the few members who have it
04-30-2019, 01:27 PM | #3 |
Small filter at front...are you referring to a crankcase breather line filter? It looks like a tiny air filter, but is meant to keep debris out of the cases in a negative-pressure situation (piston upstroke).
05-02-2019, 12:44 AM | #4 |
Thank you guys, im dumb i figured it out, btw which jets should i use in my carb if im at sea level.
