Old 08-08-2018, 02:19 AM   #1
Kuss   Kuss is offline
Head Scratching Fuxin 110cc Pocket Bike
I am working on a FUXIN 110cc pocket ATV with a LONCIN motor and a SNYA two piece CDI.
There is no spark!
The CDI main module has 8 wires coming out to the connector. The ATV picks up 6 of these.
The second module has a 5 wire connector plugged directly into it.
There are also 2 black leads (unconnected) and a two wire connector (horn maybe).
Is there some guidance you can give so I may use a 5 wire CDI?
Below I will try to show the wires and connectors:
SNYA (main module)
Gry Pk Yl
_ _ _
R Blu Yl
_ _ _
Bk Or
_ _
ATV mating connector
Bk/Wh Blu/R
O O
R/Yl
O
G R Bk
O O O
L’ LiHua (slave module?)
G `Bk/Wh R
I I I
Blu/Wh Bk/Yl
I I
R = is usually + on this ATV
Bk = is usually switched (control)
G = is - or Ground (except sometimes)
Here’s me hoping you can suggest a simple fix.
The owner’s young sons don’t need the horn.
Thanks for your consideration and help;
James E. Kuss
Old 08-08-2018, 11:28 AM   #2
Please show us pictures of the parts you're referring to. That will be much easier to follow.
110cc loncin engine, cdi no-op, no schematic, snya cdi
