07-17-2018, 04:52 PM | #1 |
Clutch basket play
Im chasing a problem with shifting. I pulled right cover and from what i can tell everything working as needed. When i was shifting i could see clutch basket moving alot. Anyone have trouble with then loose or are they suppose to float. Are they bushing or bearing style. What is torque on them?
07-18-2018, 01:06 AM | #2 |
is the basket rivited to the back gear or is there a cushing unit....
07-18-2018, 03:11 PM | #3 |
Im not sure at this point id say solid be weekend before my socket comes in to disassemble it. I was hoping the hawk masters were going to chime in. If not ill keep ordering parts till i fix it.
07-18-2018, 03:59 PM | #4 |
To be honest, it isnt much to go off of. This is one of those situations where a video of what you are describing would say a lot more.
Also, iirc, these use a bushing instead of a roller bearing.
07-18-2018, 05:10 PM | #5 |
There must be a play in clutch basket, if the engine design of your bike is similar to mine. Please, make a video of the play. My clutch has a lot of play.
07-19-2018, 01:46 AM | #6 | |
07-19-2018, 09:08 AM | #7 |
The shaft bearing behind the clutch could be going bad.
07-20-2018, 09:13 PM | #8 |
Is the play rotatonal or side to side "wobble"...
07-26-2018, 12:17 AM | #9 |
Too many possibilities - Video please
The basket can wear on the spline too, or bearing or... or ...... |
07-26-2018, 01:46 AM | #10 | |
the basket usaly runs on a bronze bush as it only rotates free of the hub if the clutch pulled in... at any other time the basket and hub rotate as one unit as they are connected by the clutch plates and springs... ..
07-26-2018, 08:22 PM | #11 |
Thanks for all the help im try to replace all parts and inspect wear and report back if any of that helps.
