08-31-2019, 09:07 PM | #1 |
Spacer for front wheel
Bought my 2017 hawk second hand and it seems to be missing a spacer in the front axle. Either missed in the original assembly or not shipped with the bike. If the axle is tightened the disc rubs. If it's loosened to where the wheel spins properly it's not tight at all. Anyone know where I can find only the spacer without buying a new wheel assembly? Or one sold for a different bike that's the same size? Perhaps a Honda?
08-31-2019, 11:32 PM | #2 |
09-01-2019, 07:11 PM | #3 |
Thanks
That's lovely it's called the shaft sleeve, on a related note do you know If the rear cargo rack matches bolts with the hawk?
09-02-2019, 07:49 AM | #4 | |
From $30 to $40 posted to the USA Or if you want to use Ebay its more expensive and only the mid size listed |
09-02-2019, 09:50 AM | #5 |
Try switching which side the spacers are on, assuming it still has two? Sometimes they get mixed up.
09-02-2019, 11:27 PM | #6 | |
Answers your question? |
09-04-2019, 11:53 AM | #7 |
It seems to only have one. The sites that sell the full wheel assembly only showed one
09-04-2019, 11:56 AM | #8 |
Should have one spacer on the rotor side.
09-04-2019, 02:30 PM | #9 |
I'd give RPS a call, and either have a local machinist turn one up (if you can get specs from them), or just order one from there.
09-04-2019, 07:30 PM | #10 |
Peace sports in Atlanta I would say has what you need
